- Dec 1, 2016
pretty much every original article Harold Hahn wrote are in the Hahn archives on the navy board site
**VIEW THREAD HERE** |
Hello Janos, I thank you for your visit and also for your very kind words and comments. Yes I will agree with you on that one, rigging the canons is not one of my favoured tasks in model ship building, but then again one can only put it off for just so long, I think that I will build the other 6- 4 pounders before tackling the rigging.Great work, Lawrence!
Cannon rigging is satisfying at the moment it is finished - but a big struggle until that point of time!
Janos
Hello Uwe, I thank you for your visit and also for your nice compliments. Yes the hint was very nice, somehow I completely over looked those Trunnions, still can not believe that I did so.The hint was correct - looking much better![]()
saw them and bought them 2 months ago when there was almost none to be had. Worried that the company had gone out of business. Glad you got some -never succeeded with cutting shape in a razor bladeHello Ship Mates
Just a little update today as I wanted to share my new set of Artesania Latins Micro Shapers for cutting the trim moldings for my Oliver Cromwell that should come in very handy once the canons are installed and rigged out..
Regards LawrenceView attachment 132815
Hello Stuglo, Thanks for your come back, yes I got mine trough Amazon.ca from a company in Austria. They look very good.saw them and bought them 2 months ago when there was almost none to be had. Worried that the company had gone out of business. Glad you got some -never succeeded with cutting shape in a razor blade
Hello Gilles, I thank you for your visit, also for your very kind comments. No the cannons and carriages were supplied by Dave Stevens over at the Lumberyard as a kit. I had to build and add the Trunnions Caps along with the brass rings and so on. The cannons were drilled when they arrived to a depth of around .137" or 3.5mm, on the 9 pounder, hope this helps.Hi Lawrence.
The guns look good.
Did you have to drill the bore? if so how far down?
Thank you.
G.
The cannons were drilled when they arrived to a depth of around .137" or 3.5mm, on the 9 pounder.
Hello Stuglo, I thank you for your very kind words. Yes the jig dose make rigging the Breaching cable much easier.brilliant. will use myself
