Does anyone use these types of 6 in 1 mini lathes? Such as https://www.amazon.com/gp/product/B...QPMZ4&linkId=8e5664014c2e5d8541ead5851d1302be
I wasn't asking about that one in particular. I asked about those types,Hello, Dcox1961.
IMHO, this is more educational toy than a tool. Don't expect accuracy or anything precision. You may be able to turn balsa wood (only).
Hello Dcox1961, All those 6 in 1 mini tool are really not practical. They are not powerful enough and will not be suitable for modeling purposes. But this is just my opinion, and personally, I wouldn't consider purchasing.I wasn't asking about that one in particular. I asked about those types,
They do make ones out of metal, once again the one I posted was just an example of what I was asking about. I would never buy one out of plastic it was just the first one that popped up when I was looking for an example.Machine tools made of plastic? Ha-ha-ha. Total waste of money. Besides any tool which is made to serve a multi purpose appears to serve none.
it ones need for a lathe are limited, those bead making lathes are adequate for ship modelling where only occasional use is required.I've got one of those Banggood mini lathes, not the 6-in-1 but the ones advertised for making beads. First, it's not as bad as it looks, providing you don't have high expectations - It cost about £40. It will only do wood and it's fiddly to set up but, once it's up and running it will turn small items, taper masts, etc. I'd rather have a Proxxon, but hey ho.
So you have used and own one of those types of tools. Do you find yourself using all the features or do you just keep it set to one function? I have a whole workshop of full size wood working tools. I was just looking for a small multi function tool for my small desk. I really don't want to have to buy a bunch of small high quality power tools for the few times I will ever use them. I don't see changing the setup a problem for me as it wont be a tool I use very often. Yes there was an all metal one I had seen that got my attention I just lost the link and couldn't find it again.........the one I linked was just an example of the tool I was inquiring about. I would never buy a plastic tool like that.I agree with @stuglo , this thing is just a (not so) cheap copy of the original Unimat. I hav the original since more than 20 (!) Years, still working fine for wood.
Here is the link to the real thing: https://www.thecooltool.com/produkte/unimat-1/unimat-classic/
For metal work I use an old DDR Lathe also about that age, named "Hobbymat", the small Unimat will not get the work done.
Regards
Gerhard
I have one of those but the 4mm chuck means it's very limited. Any idea how to remove the chuck? And is there a 3 or 4 jaw that will fit??I've got one of those Banggood mini lathes, not the 6-in-1 but the ones advertised for making beads. First, it's not as bad as it looks, providing you don't have high expectations - It cost about £40. It will only do wood and it's fiddly to set up but, once it's up and running it will turn small items, taper masts, etc. I'd rather have a Proxxon, but hey ho.
on those lathes is there a pass through on the head stock so you can machine longer pieces? or do you have to cut the stock material down to fit?I have one of those but the 4mm chuck means it's very limited. Any idea how to remove the chuck? And is there a 3 or 4 jaw that will fit??
