My FIRST build: Krick Borkum with MSM 3" Clyde Steam Plant [COMPLETED BUILD]
And so it begins...
Please join me in the build of the Borkum (which has been done many times before). My nickname for her will be "Cariad" meaning darling/love in welsh. As this is my first build I
ask "silly" questions to gather your input, please feel free to give any advice and/or criticism. All welcome.
First thing I did was unpack the box from Germany and organized the parts in my office/workshop. Next task is to number all the pieces as per the instructions then put together/glue the base and begin my journey - As they say "Excelsior" which translates as "Onward and upward"
Derek Ellis, north of the 49th parallel
... locked in my workshop until further notice ...
Welcome aboard SOS, Derek!! I am taking an empty (available) seat and will watch as your build progress! Have fun building!
Neptune (John),
As I cut the pieces out of the template, I notice there is 2 sides to the plywood pieces, one whitest, and one with grain. Which is side up or side down?
Derek
Hi
Almost all ply has an A & B side. The fascia side ( A) is normally the cleanest, whilst the (B) inward is the grainier or worst looking side. I normally mark all my kit parts A & B as well as the number. You can normally tell which is which if you look at the parts plans as they have them laid out in a specific way per precut board and you can only put the whole thing down to match one way. The A side is the position shown on the parts template
I find in this way you can put the parts together so that they all face a certain direction. I have found with some kits where there is a multi part building it matters ( The AL riverboat was a classic example of this). For the hull it normally does not matter, but there may be cuts that are side specific.
Following with great interest.
Neptune (John),
Derek
G'day Derek, I think with this kit it doesn't really matter as all the plywood surfaces that show are planked, here is a link to my build log on this forum, the first few posts are about building the Stuart Turner Engine, and then it goes on with the actual launch build, I hope it helps you, I'm still waiting to be able to get mine on the pond, I have to sort some of the electrics out, and I did do a few modifications along the way, I will attach a pic of how she looks at the moment, any questions just ask,
best regards John,
Neptune,
You (and many on this forum) are the resource I was hoping to find. I have returned to model building after 50 years and then it was plastic airplanes with glow plug engines. A child of the 50s. I don't have the knowledge and nomenclature of all things marine. Your build is going to help me immensely. I thought the Krick instructions would be more germanic meaning precise. They assume more marine and/or model building expertise than I have. I feel better now to solder on. The rudder stiffener part threw me for a loop at the start. Thanks for sending me the link to your build. It is reference on my tablet as I proceed. Will post my progress soon. Saw some pictures of my lake in West Quebec yesterday - the ice is leaving, hope after this crisis to get there possibly in June to test "Cariad" and steam plant a little. No sure where I will be in the process, probably very very early. At what part of the build process does one test out the buoyancy/weight balance?
Cheers,
Derek
I was very lucky with my build, with using the Stuart Turner Engine plus the electric motors and batteries, the main batteries I installed under the main floor beneath the fake boiler, I didn't need any extra ballast,
Best regards John,
To Neptune/Torpart,
What did you do you to waterproof the Borkum rudder after you painted or stained it?
D.
To Neptune/Torpart,
D.
G'day Derek, the paint alone should be enough for the rudder itself, the only other thing I did was to put a little grease on the rudder shaft before slipping it up through the rudder tube,
Best regards John,
Hi guys, I'm back. Due to the COVID-19 crisis, I am trapped in my office/workshop. I work a little on my communications projects then a little cutting, gluing, staining etc. I want to first start by saying I can't tell you how helpful this site and forum is to me. It has helped my mental equilibrium. As a first time wood modeller (many year ago I made little plastic war planes), this is not as easy as I thought. Learning new skills, different tools, fat fingers, glues of all types, and a world of clamps and tape. A big shout out to Neptune/John and Torpart. Their build logs have save me time and mental anguish. What I found out from all of you is that it is OK to be your own modeller and build the boat you want, not what the instructions dictate. I can be creative within the bounds. I can colour in and outside of the lines. My start1.jpg1a.jpg2.jpg3.jpg4.jpg
I learned early you have to take your time when assembling. Like the adage - measure twice cut once. You see here I glued the stern support backwards. Who knew the tabs fit the other way. Course correction and back on track.
Let's do "flooring" The instruction say I can use the opening for blast, we will see as I plan a MSM steam plant that will cover the area. Will do a test of balance near the end and fill it if needed.10.jpg11.jpg
This is my work in progress. I have ordered my servos (stuck in the Bahrain for delivery) and the MSM steam plant but due to COVID-19 may take weeks. MSM sent it for delivery but I hear shipments to Canada might be suspended until there is sufficient airplanes to take cargo. I solder on. I ask am ready for sanding, staining and varnishing as I wait for those items. Can't lock anything down until I get the other "parts" - Yes/No. I have had a conversation with Neptune/John re: painting the hull. I want it to carry Welsh colours and want to call it "Cariad" love in welsh. 12.jpg13.jpg14.jpg15.jpg16.jpg17.jpg
Any advice or help is much appreciated. I am thoroughly enjoying the journey and learning so much. In fact so much that I look forward to my next build after I learn from all my mistake, and there are many. As I said earlier, I am so impressed and in awe of all your talents and can only hope I get near your skills and precision. Right now it is all about learning how to do just that. Thanks for being there.
Derek
