Thanks. That will be helpfull. One dayA small comment from russian-speaker about Mr Shevelev:
Pear-wood, two layers of linseed oil or Danish oil; and then patina (Idea Liquid Bitumen #741)
Because it is early in the process, and you have made such an attentive approach to the gunport openings, I will speak up and back Uwek on his point. I think it is better to make good joinery, in the "flat" of consistent thickness, and then to taper and do whatever one needs to for the bow. If there's one thing that I've learned about paint, it is that it won't hide these sort of discrepancies; you will always see them, and for me - it would be a point of regret. I offer this always with respect for your personal choices. Just my point of viewLooking good -
maybe you have to be a little bit more careful with sanding not to round up the edges - they should be sharp, so the joint will look smaller
Not quite.Something similar to the one below ???
, great! Full-disclosure: while I am a woodworker who makes furniture, I am a plastic model builder and haven't yet attempted to do what you are now. That being said, I am very familiar with the tools you are using. The first thing I would make certain of is that my bandsaw table is perfectly square to my blade and that the blade is properly tensioned and tracked so that there is no deflection in the cuts.
Sth like this?sanding blocks
Like mine on last photo?sanding sticks
