Canoe21
Lawrence
Hello Arthur, I thank you very much for your visit to my build log and the very kind comments, Thanks.Hi Lawrence.
Looks like there's been a productive period over the last week or so. Looking good!
Regards Lawrence
Hello Heinrich, I thank you for your Easter wishes they are very much appreciated Bernadette and I send along our also belated Happy Easter wishes.You have made very good progress, my friend. A belated but very blessed Easter to you and your family as well.
That’s a Great Flooring, Lawrence.Hello Ship Mates, It has been a busy week here in the The Old Ship Yard. We started the week of soaking the two Limber Stakes over night in water so as to be able to bend thin in the AM. We clamped and bent the Limber Stakes to the hull in order to set the curve to the hull. This left us unable to work on the hull for the day, so to fill in this time frame we decided to work om the Parq. Flooring in the Great Room. Once started we found it hard to put down so we just had to finish.
Regards Lawrence
Hello Shota, I thank you for your very kind words and encouragement.Dear Lawrence
the Flooring of the Great Room came out beautiful![]()
Hello Peter, Yes I sure do like the pattern, it should fit well with the HMY Fubbs.That’s a Great Flooring, Lawrence.
Hello Arthur, Thanks for the Heads Up, Yes you are very correct there, the Great Room Decking was just a fill in for the Limber Stakes to set and bend.Very nice job Lawrence.
Don't be in too much of a hurry to glue it in place, it's nice to be able to lift it out at this stage.
Hello Daniel, Yes the rudder, this I wanted to get out of the way as it required a fair bit of fitting, I still have to touch it up a bit but we are satisficed with the results so far with a little more help. Great work you are doing on your Cash Registers , I still remember these from far back, was always amazed at how the cost always popped up.Nice job Lawrence. The rudder is something I was pushing to do it later. But I think the time has come on my built. I am getting again the model ship building bug, after a brake with my Cash registers hobby. Still restoring them, but it's time to change a little and go back to Fubbs.
Cheers
Daniel
Hello Johan, Thanks for your very kind words, yes the Great Room Deck is quite large at 11 3/4" or 298.45 mm long and 9 3/8' or 238.125 mm wide. Not at all like that of the YQ-Bluenose.I was totally flabbergasted by the looks of the Great Room's floor. Not only by the quality of the woodwork, but also by it's size. So I took another look at your builds' title and found you're building a 1:24 model. Now the size of the Great Room's floor makes sense.
(Still thinking 1:72 dimensions..)
For you:Hello Daniel, Yes the rudder, this I wanted to get out of the way as it required a fair bit of fitting, I still have to touch it up a bit but we are satisficed with the results so far with a little more help. Great work you are doing on your Cash Registers , I still remember these from far back, was always amazed at how the cost always popped up.
Regards Lawrence
Hello Daniel, Golly but she is a beauty, Well Done.
Good evening Lawrence. You totally owned the great cabin flooring. Well done. Cheers GrantHello Ship Mates, It has been a busy week here in the The Old Ship Yard. We started the week of soaking the two Limber Stakes over night in water so as to be able to bend thin in the AM. We clamped and bent the Limber Stakes to the hull in order to set the curve to the hull. This left us unable to work on the hull for the day, so to fill in this time frame we decided to work om the Parq. Flooring in the Great Room. Once started we found it hard to put down so we just had to finish.
Regards Lawrence
Hello Grant, Thanks for your very kind words, yes the Great Cabin Decking was a lot of very interesting fun.Good evening Lawrence. You totally owned the great cabin flooring. Well done. Cheers Grant
