Parts review Aftermarket naval guns parts to upscale, Part 2/3
Continued from the previous post...
Completed cannon images
Well...with those images shining, Part 2 comes to an end. I have a total joy working with those small kits. Specifically with the carriages, their assembly is a breeze. The barrels are very good quality! One of my observations and comments, the trunnions diameters should be bigger for all sizes. This is not a challenging part, and if you think the same, a bigger diameter brass wire should do it. The PE parts are great, the frets have all the parts to assemble the gun, plus additional eyering and eyelets to rig the cannons and the bulwarks. However, I wish the linchpins would be included in all PE kits other than just a 50mm one.
And now is the small quiz, just to find out how attentive you are reading. Do you see the difference between the blackened and brass cannons?
Thank you for visiting this log, but don't go away for too long. We will rig those cannons, Yeah, you heard it right
a small teaser below...
Excellent! Thank you.
Greetings all. This is way long past-due log of Part 2 of 3 series: Accesories\Uspscale mini kits of naval guns. To those of you who came directly to this post, please follow the below link to get familiar with our discussion about aftermarket naval gun mini kits.
PART 2
In the first part, we have an overview, kinda of an open box of mini kits available at our disposal if we would like to upscale the look of the naval guns: their barrels, carriages, and small PE parts to those who would like to present the gun with tiny details. So...without further ado, let's begin.
This is our ultimate goal for today's discussion
The carriage
Let's take a look at the typical British naval gun using the image below. We will assemble the carriages so they look similar.
The parts for the carriage are provided in two laser-cut Pearwood sheets. Each kit will have a thinner sheet, that contains parts for left/right marriage sides, all 4 trucks (wheels), transom, and bolster. The thicker sheet will have front and rear axletrees and quoins. Below is the sample for the 35mm barrel.
I am removing all the parts to clean the laser char where it is required. Some parts will require shaping before they are assembled. Let's start with both axletrees. For the tracks to fit, the axletree ends require some rounding.
View attachment 414823 View attachment 414824
Obviously, you can do it with a flat file and/or hobby knife, I suspect they will look OK, but likely to be uniform. To ease this process, I made a custom tool using different blunt needles. They are typically labeled by gauges where the gauge number, the smaller the inside diameter. (see the image below).
View attachment 414853 View attachment 414854
Pick the blunt needle that will make the dowel the same size (or close enough) as your inside diameter on the truck. To make the tool, you will need a triangle needle jewelry file and make 4 cuts like in the image below. Don't worry if they do not even, they should only cut the wood. Here on the image various tool sizes for different axletrees. The tool is better used in the drill press but with some try and error, you can do it in your favorite rotary tool on slow speed.
The next step is to prepare the transom. Because the carriages' sides are not parallel to each other, each side on the transom required shaping. There is a laser mark as the guide to help you remove only the necessary amount.
View attachment 414839 View attachment 414836
Alright, all parts are preshaped where necessary and ready to be assembled to make a carriage. YAY!
I start with the transom, it will be glued to the front axletree. Please note the two laser marks., you will glue the transom between those lines like so on the images below. You may click on the individual image to see a larger view.
View attachment 414856 View attachment 414857
Moving ON, time to glue the carriages' side pannels. Each carriage has notches to accept the front and rear axletrees, also there are laser marks on the axletrees to position the sides. Glue everything together including bolster. NOTE: you will have to shape the bolster so it will fit between the carriage's sides.
The last step is to glue the quoin and the stoolbed (one simplified unit), but this will require a gun barrel so we can properly manage the angle. Believe me or not, but that's it for the carriage itself. At this point, it should look similar to the images below.
In my images, I use parts from different kit sizes, as I assembled them all. You may find slight differences between the images.
Working with gun barrels.
Assembling the carriage was fun, wasn't it? The carriage does look great and I must admit - all parts fit nicely! If you intend to upscale only kit carriages, your mission is accomplished. However, if you want to replace the naval gun with upgraded barrels, then continue reading.
For the most part, they (barrels) don't require much work. From the supplied brass wire I will need to make a trunnion and clean it from oxidation before blackening. However, I recommend purchasing a PE kit, not that the kit contains capsquares, and various hooks/eyebolts for rigging the gun, but it includes the linchpins (at the time of writing only for the 50mm kit) and the Royal Emblem. Yeah...you want the royal emblem, for sure. Just so you have an idea of what is the PE kit, check the image below.
and Royal emblem in the macro image
Back to the barrels. The wire diameter supplied for the trunnion is slightly smaller than the hole. If you don't know how to solder or simply don't want to, you can blacken all the parts separately and glue them together. However, I will be using the butane torch and silver solder paste and solder all parts together before blackening.
Using the carriage, measure and cut slightly longer wire for trunion, so you have enough for the final shape from both ends. In the middle of the trunnion part make a grove half of the diameter. Put some soldering paste and insert it into the barrel. Remove any excess solder from both ends and... Solder it. Heat the fubsy parts first and spread the heat toward the thinner part of the barrel. You should see the bright solder between the hole and the wire. The job is done! While still hot, dump it into vinegar to remove oxidation.
The next task is to solder the Royal Emblem. Oh..oh..we have a slight problem. The emblem is dead flat and will require some round shaping.
Continue on the next post (25 images limit)
1. Great presentation. I have been building these things for 40 years and still learned a few things.
- bill36
Jim,
Wow, Your cannon carriages are magnificent ! I just learned a lot from your tutorial. Before I read your tutorial I ordered several 30mm cannon kits from Drydockmodels. Excellent quality. They arrived a few days ago. I sent Zolly a PM letting him know how good the kits are. I assembled the first four carriages and they came out Ok. Now that Ive read your tutorial, I am eager to try your techniques for the next few. I ordered the blunt needles to make the rounding out tool for the wheel trucks..I also ordered some burrs to shape the end of wire and I'll try to find the etch rollers (DSPIAE). I will also try to make the tool you made to round the capsquares. I am not an experienced machinist but I will use my Sherline milling machine. Let's see how it goes. BTW, You should make a few of these parts and sell them to SOS members !- Thanks a lot. This is fun. Where is Uwek ? I hope he is on vacation and Ok, just haven't seen any posts since mid December.
Best
Alex R
Thank you for the compliments, Alex, and I'm glad the review/tutorial is handy. I cannot make parts commercially, I have neither tooling nor desire. As you mentioned, making parts is fun! Please let me know how it goes, I will be happy to help.
PART 2
The carriage
For the most part, they (barrels) don't require much work. From the supplied brass wire, I will need to make a trunnion and clean it from oxidation before blackening. However, I recommend purchasing a PE kit, not that the kit contains cap squares, and various hooks/eyebolts for rigging the gun, but it includes the linchpins (at the time of writing only for the 50mm kit) and the Royal Emblem. Yeah...you want the royal emblem, for sure. Just so you have an idea of what the PE kit is, check the image below.
Back to the barrels. The wire diameter supplied for the trunnion is slightly smaller than the hole. You can use the reamer or drill bit to slightly enlarge, but don't make loose! If you don't know how to solder or simply don't want to, you can blacken all the parts separately and glue them together.
However, for this exercise, I will be using the butane torch and silver solder paste and solder all parts together before blackening.
First, I prepared the wire. Using the carriage, measure and cut slightly longer wire for trunnion, so you have enough for the final shape from both ends.
As you can imagine the trunnion (wire) should be perfectly fit in to the barrel's hole. So... The actual question is where to put solder? Obviously, the only way is to put solder from the sides, correct? Yes, but then, you are risky that solder 'jumps' on top/bottom or any other place but not inside, between the trunnion and hole. So, I decided to mill a groove and put the solder there, in this case the solder will melt inside the barrel and guaranteed not spilled across. In the middle of the trunnion part make a grove half of the diameter of the trunnion wire (see the sketch below)
Put some soldering paste and insert it into the barrel. Remove any excess solder from both ends and... Solder it. Heat the fatty part of the barrel first, and evenly spread the heat toward the thinner part of the barrel. You should see the bright solder between the hole and the wire. The job is done! While still hot, dump it into vinegar to remove oxidation.
The next task is to solder the Royal Emblem. Oh...oh... we have a slight problem. The emblem is dead flat and will require some round shaping.
Great idea for rounding the axels will give it a go Jim, Cheers
