Today was sanding day. Tapering all the masts, bowsprit, boom and gaffs. Last year, when I built the "Red Dragon", I used a battery powered drill, thick gloves, and sandpaper to taper the masts down to size. I was going to do the same thing, but with crappy weather and not trusting myself not to damage the dining room table, I decided to take a different path. It actually worked out pretty well. Holding one end of the wood dowel, I used my small hand sander with 80 grit paper and went to town... Long strokes, bearing down towards the tip, while at the same time rotating the dowel with my left hand. Then once I got the taper diameter down to where I needed it, I swapped out the 80 grit for some 240 and sanded them perfectly smooth. Certainly no where near as fast a process as using the drill, but it worked surprisingly well. Another technique to use in the future...
With the foremast, I just sanded horizontally to get an even diameter at the top inch of the mast, and then used an x-acto knife to gradually whittle down the beveled ledge below it. Again, more careful sanding to round off that chiselled part, but overall, success and no blood loss in the process. I consider that a win-win kind of evening.
