Kısaca anlatayım: Bu süreç için iki emin olunması gerekiyor,
1...GÜVERSE BASACAĞI
2...metin etiketi
GÜVERSE BASACAĞI=NEDİR= ÜLKEMİZDE KUYUMCULARIN KULLANDIĞI TEMEL BİR ALETTİR. Bu aletin ağız kısmı içe doğru yarım daire şeklindedir ve ağız köşeleri keskindir. Ülkenizde bu aletin ne olarak adlandırıldığını öğrenmelisiniz. , ve foto 1 foto 2 ve foto 2a
metin etiketi fotoğraf 3
Metin etiketini sert bir yüzeye yapıştırıyorum, bu zemin pleksiglas. foto 4
Netlik için siyah kalemle renklendiriyorum. foto 5
Çekiçle hafifçe vurdum foto 6
Foto 7 yazı etiketini kaldırdım
sonucu keskin uçlu bir maket bıçağıyla yerden kaldırın ve görünür sonuca yapıştırın
foto 8 ve foto 9
Very interesting technique - many thanks for sharing and explanation
After the holiday, there were still some chores waiting at home. But eventually back at the shipyard.
To fill the open spaces with the remaining frames, I had to adjust the workaround a bit. The template for the frames come from Fushion. But I didn't draw the profiles for the floor in the aft ship there.
That's why I placed a print of frame 3 in the model:
I cut 2 recesses in it so that the mold fits over the profiles for supporting the deck beam and the floor profiles.
Arrow A points to the position where I have to place the horizontal profile in the frame that supports the floor profiles.
Here you can see the filling with frames 3 and 4, both made in the same way:
Arrows A point to the horizontal support of the floor profiles in frames 3 and 4.
I also always check the course of the outside of the frames. I was not satisfied with the shape and course of the small frame with sketch plate -1. This one adjusted.
For the filling between frames 5 and 9 I have to adjust the method again. Due to the outer profile for the floor, see in the above picture arrow B, I cannot place the paper templates in the model. Or I have to cut out a very long recess.
A suitable paper strip placed at the position of frame 7 and notches made at the position of the inner profile for the floor, see arrow C. And that of the keelson, see arrow D. The 2 horizontal profiles come at those places.
That transferred to the paper template for frame 7:
C is for the support of the floor, D for the keelson.
I can now continue with the construction of this frame. And apply this method to the remaining frames.
Dear Peter
Nice to see you are back to the shipyard!
It is pleasure to read your explanations and see in pictures , the challenges you face in building, and the creative ways you take to move forward and in a way that inspires respect.
As I told you before, this is a special and unique model thanks to your professional and beautiful work.
Dear Peter
Thanks for your very nice words and compliment, Shota. My approach is that if I am going to solve a 'problem', I might as well visualize it. Considering the type of model, you could say that this is a modern ship. But the technique is based on the old frame construction, with more modern material. So I estimate that others may also encounter similar problems. Who knows, my explanation may give a push in the right direction.
Ps: I wish you a pleasant time in Evian.
The construction of the starboard part is finished:
As I have already written, it was a good thing that I started at the front. With the experience gained, I could now complete the back. If I had started at that side with frame 0, I don't think I could show this acceptable result now.
The picture was taken from above with the building template tilted on the building floor.
On the freestanding building template:
At first glance, the distance between the frames is not the same everywhere. That is correct. I will explain that later.
From a slightly lower position.
Also, some frames and retaining frames do not all point in the same direction.
Seen from this side, that is even more noticeable:
But here it is further reinforced by the strong double curvature of the frames. Which sometimes also gives a distorted image.
Some further explanation:
In the insert A (at the bottom of the photo) a part of the line plan that I used in Fushion to draw the frames. The distances between them differ. I have drawn the frames at the position of vertical lines. Actually, that is the position of the plate between the keel and the keelson.
And depending on how the deck profiles are placed, the frame and the reversing frame are placed on these plates.
I have shown that schematically in insert B. That corresponds to the construction method of frame 8.
In blue the L-shape deck profile where the flat top is facing left. The yellow shoulder corner plate is placed right against the standing side. And there again right of the red profile of the frame. See the small upper photo insert.
A little below that, the red reversing frame that is placed left against the frame starts and runs up to the cleat plate and bends horizontally over the top of that plate. See the small lower photo insert. That plate is again left of the frame and in line with the shoulder angle plate.
The black arrow points to the plate that is the basis of the placement.
I have numbered and framed frames 8 and 9. The horizontal top of the profiles point away from each other. The mizzen mast is secured between these profiles. So against the 2 flat sides of those profiles.
The frames point towards each other again. The retaining frames away from each other again.
In this way, the direction of the deck profiles, location and function are bound in several places in the hull. And determine the rest of the construction of the frames.
The rear was quite complex in terms of construction. The floor has the necessary horizontal profiles in which the floor beams will rest:
Between the deck and the floor 5 temporary uprights to keep the deck in position.
The floor is supported in the middle with 9 uprights. The Donkey steam boiler and the mizzen mast rest on that floor.
With an addition to the previous explanation:
The blue arrows point to the direction in which the flat top of the L-profiles of the deck beams point.
At frames 8 and 9 they point away from each other. The yellow arrows point to the retaining frames that also point away from each other. Because the frames it self ........
At the top the vertical lines that indicate the position of the shoulder angle plates. Their mutual distance based on the nearby placed frame of the line plan.
At the end a calm picture from a different angle:
All curved profiles that from every angle again provide a (whether or not distorted) different image.
Now to work on placing a lot of rivets before this part can go to the paintshop.
Then there will be pictures of this whole starboard part.
You guys are always ahead and nothing to add, then...
But I always said that your build Peter is one of the unique, if not the unique build I've ever seen! And if one thinks, I am no longer wonder, let them think twice! I still don't know how this is possible... Obviously, it is, as I see her! Bravo, mon ami!
I agree with all above... They took the words right of my mouth. I'm seen this build in real and I can tell it is more impressive what he shows us when you see it in real. These parts ware small and so accurate.
Peter is a master at small scale builds. Either he has elf’s chained up somewhere or he has a ray gun to shrink himself to work on it! ROTF
