I would think a line would run from a ring in the corner of the sail to the piece that x6 is attached to. I would think a single block, and tied off on a belay pin or something like that.I’m looking for examples of lateen sails. Anyone have an idea how the aft bottom is secured? It doesn’t show on the plans. View attachment 210348
Do you mean through an eyebolt to a belaying pin? The only belaying pins are near the mizzenmast. I suppose I could tie it up to the saddle looking cleat thing on the side, but those spots seem to be taken. The plans seem to leave the end of the sail dangling. I’ve looked at some lateen sails and how they operate. They seem to be attached aft-center. I would think you just untie when you move the yard to the lee side when you tack and don’t want the sail to rub against the mast.I would think a line would run from a ring in the corner of the sail to the piece that x6 is attached to. I would think a single block, and tied off on a belay pin or something like that.
I"ve got thousands... be glad to send you a few/////Rats! I’m short 7 nails. I guess I lost one on each of the 7 seas. View attachment 209388
Very punny!I have all this info on the tip of my tongue and dont know how to relay it.... x6 is a block,, probably has 2 to 3 holes for rigging.. the line goes to a cleat....
...as mentioned earlier...you should see my next postI have all this info on the tip of my tongue and dont know how to relay it.... x6 is a block,, probably has 2 to 3 holes for rigging.. the line goes to a cleat....
Something like this, either a single or a pair of single blocks. Block tied to corner sail with ring or hook down. Line seized to upper single block down through lower single block siezed to S-hook or hoop attached to an eyebolt. Line back up through the upper single, back down and tied off somewhere that makes sense.Do you mean through an eyebolt to a belaying pin? The only belaying pins are near the mizzenmast. I suppose I could tie it up to the saddle looking cleat thing on the side, but those spots seem to be taken. The plans seem to leave the end of the sail dangling. I’ve looked at some lateen sails and how they operate. They seem to be attached aft-center. I would think you just untie when you move the yard to the lee side when you tack and don’t want the sail to rub against the mast.
keep lookinyou got the right idea,,, double block tied to a cleat... read more books.. they;re all in there..reseatrch...
Ah, yes, Reggie, but the sails and the rest of the rigging...Great progress Vic. It's looking real good. You're headed towards the homestretch. Time to sit back and admire the fruits of your labor.
