Bluenose 1/64 MS2130 by TechTrek (Chris) [COMPLETED BUILD]
No I didn't wash the fabric first, too much thread shedding along the edges already so I decided to just do it out of the package. I'm not planning on wetting the sails for shaping, just hitting them with the blow dryer and spraying starch to stiffen.
Any thoughts of giving them some age? Or are they going on fresh and new? The fabric seems to already be off-white...
NIce suit of sails. When I asked about washing it was for the full piece of fabric before any cutting. I used the spray starch stiffener and hair dryer on my pilot boat with good results. Your schooner is nearing her first outing. Rich
Oops...Just realized in my excitement to sew sails that I forgot the contour around the trestle trees and masthead on the 2 gaff sails. My bad, need to pull apart and redo those 2 seams as they are not straight but kick in about 15 mm. Time to go back and edit a previous post. :eek: :oops:Cautious
Previously I just used a fine pointed large needle (one of three sizes for drapery work) pushing it through sufficiently for the size hole that I needed. Bolt ropes are not mentioned with the schooner but I am sure that they were present, inside Bluenose II Aft end main boom.jpgor outside of the hemmed edge with either a metal grommet type just inside the edge or a loop on the corner of the peak, clew, and tack. I put up the set of these at the main boom end in the Bluenose II photos to clarify my mental image: two in the bolt rope sewn inside and three in the hem itself; along with the metal reinforced holes for tying the sail to the boom. I'll go to search out the jib stay connections.
My progress is as much research as building but I did get the rudder and brass pintels/gudgeons attached with small short black oval head "nails" after two days work. I have to learn how to better use my drill press and the small bits for holes in the 1/16 inch strips as my jig did not hold the strip securely and the bit wandered breaking several bits.
I hope that bending your sails to the hoops goes well. RichBluenose II Aft end main boom.jpg
Previously I just used a fine pointed large needle (one of three sizes for drapery work) pushing it through sufficiently for the size hole that I needed. Bolt ropes are not mentioned with the schooner but I am sure that they were present, inside View attachment 203110or outside of the hemmed edge with either a metal grommet type just inside the edge or a loop on the corner of the peak, clew, and tack. I put up the set of these at the main boom end in the Bluenose II photos to clarify my mental image: two in the bolt rope sewn inside and three in the hem itself; along with the metal reinforced holes for tying the sail to the boom. I'll go to search out the jib stay connections.
I hope that bending your sails to the hoops goes well. RichView attachment 203110
Nice pics
Here is my sewing method for the mast hoops.
  1. Create a double knot in the end of your thread. I use a heavy weight thread.2E5A9E48-82A8-432E-B46D-121C34F88531.jpeg
  2. Insert needle from back side of sail to front and pull until knot is tight against the sail.0B0AAE49-80BC-46CE-9E11-D2504B1D57D3.jpeg
  3. Bring needle back through gap between the sail and mastE16CEBA8-BB61-4FE4-8BFC-FE3CBD367334.jpeg
  4. Bring up mast hoop and drop needle down between the hoop and mast35A4EA91-0A0A-4688-8593-92CC9203E7EE.jpeg68F25E9E-D11B-4F86-A90B-B8C34AF322D9.jpeg
  5. Push needle back through the sail to the good side7DC2B024-DD7E-4663-AE52-7C08922FEA6F.jpeg
  6. Push needle through sail from front to backD004605E-10FE-45EC-BD02-25B37CBD33EF.jpeg
  7. Loop thread a few times around the needle and feed back through to the front49F322FD-40E7-4AF4-AB25-A0567A6798FE.jpeg
  8. Bring needle back through one final time and trim off67071B9A-02D2-43DE-A960-C1F5634EAB70.jpeg9A314A0B-6925-46A4-B697-4C80ABDC86FE.jpeg
Shot of top 8 completed hoops
  1. Create a double knot in the end of your thread. I use a heavy weight thread.View attachment 203492
  2. Insert needle from back side of sail to front and pull until knot is tight against the sail.View attachment 203493
  3. Bring needle back through gap between the sail and mastView attachment 203494
  4. Bring up mast hoop and drop needle down between the hoop and mastView attachment 203495View attachment 203496
  5. Push needle back through the sail to the good sideView attachment 203497
  6. Push needle through sail from front to backView attachment 203501
  7. Loop thread a few times around the needle and feed back through to the frontView attachment 203498
  8. Bring needle back through one final time and trim offView attachment 203502View attachment 203499
I used a different technique with two needles on each end of a thread. First looped a girth hitch around the hoop and then took one needle through one side and the other through the other side. Then both back with one twist around the girth hitch threads between the mast and sail luff ( one above one under) and tied them off with the first half of a square knot and secured them with a very small touch of CV, letting it set and trimming the ends off They could have been passed back through the luff hem and then with the toothpick dot of glue set and trimmed flush with the hem face on each side. I think that your method is working well for you and the results well produce a good schooner. I see that you laced the mainsail to the boom instead of tying each one as with the actual manner. It is easy to chip from the sideline when a good response would be OK, you do it! You are going to have a well done schooner. Rich
Question total off track from bending sails. . . How did you do the holes in the brass strips for the deadeye "chain plates"???? You had to solve this and I need your experience. Thanks, Rich
I cut all the strips. Glued them to a piece of wood with markings for where the holes go. They were all glued down about a brass strip width apart. I then glued pieces of hardwood strips on top of the strips and between the holes. Almost like a grate pattern now. Let it dry. Tapped a dimple at the centre of each hole location with a finishing nail and then used my fake dremel at medium speed with a new #69 drill bit. Gentle pressure so it didn’t grab too hard. Took me a bit to get the method, hence my burning through too much of the brass strip stock. o_O ;)
How did you get the glue to release without bending the brass strips? I understand that you glued the hardwood strips perpendicular to the brass strips, locating those between the 3/16" o.c. hole spacing, right? I do have some Buginga from Africa that is in thin widths that I can cut and may try it in the manner that you describe. Clamping the "mat" down will still require getting it parallel to the inverted T grooves in my XY table on the drill press. I have receive several recommendations/suggestions from other members so I have a spectrum to work from. Thanks for your reply. Rich
