Bomb Vessel Granado 1742 - Cross Section - 1:32 Scale - Scratch Build by DocBlake [COMPLETED BUILD]
Thanks, guys!
The diagonal bulkheads are the most difficult because there are two angles on each end that need to be cut to form a point. Fortunately, the angles are 45 degrees and the "point " is a 90 degree angle! I set my Byrnes disc sander table to 45 degrees and "cut" the angles very carefully. The photos show some finished bulkheads and how they butt up against each other. The rabbets are to accommodate the side covers, which are part of the mortar pit housing. I'm not sure if I'll include this!
Thanks, Heinrich!
I prepared the diagonal bulkheads for installation. The backs of the 4 bulkheads are supported by diagonal carling which are inset into mortises in the deck beams and trimmer beams. I decided to make life simple and simply butt the diagonal carlings in place. I carefully cut them to size, then glued them to the back of the diagonal bulkheads. The bulkheads are built with two boards. I simulated this by scoring a line and marking it with a pencil. Once the glue dried, these were epoxied in place.156.jpg157.jpg158.jpg
Thanks, guys!
I started work on the hatch. The coamings are 7/32" thick bloodwood and jointed by half laps at the four corners. The coamings are also beveled inward by 10 degrees on all four sides. How to do the beveling easily and accurately? I decided on a jig!
Basically the jig is a slice of wood, angled at 10 degrees from the horizontal. When the face of a coaming is sanded such that it is square up against the Byrnes sanders disk, you know the angle is a perfect 10 degrees. The hatch frame is attached to the jig with two sided carpet tape.
Sanding the four sides took about 20 minutes.
I needed to figure out a way to make the hatch cover boards. I planned on using boxwood for the color contrast. The boards are about 5/64" thick with a very slight curve to them that matches the curved coamings. But bending the curve and getting the precise length right cutting strip stock was going to fail! Too hard to get consistency in the four boards. Here's what I did:
I cut up a boxwood blank the fit into the recess where the boards sit. It was thick enough so it stood just proud of the highest point on the curved coamings. Then I traced the coaming top lines onto the 4 edges of the blank. I used double sided carpet tape to tape the blank to a block of wood, keeping it perpendicular to the table of my disc sander, and parallel to the disk's face. Using my variable speed disk sander on LOW speed, I sanded the curve into the blank!
Once I was satisfied with the curve, I took the blank and simulated the four boards by scoring them in and darkening the score lines with very thin pencil lead. It worked out well!
Do you remember the old hair coloring commercial " is it real or Carole"?
Well your work is of great quality and unless we were told it wasn't separate boards, most would never know.
I enjoy learning of new ways to do things as you show us how you overcome obstacles and issues in this build.
Keep it going, I need more since we are going back into semi-lockdown.
With lots to do around the house, I've not had much modeling time. I did finish the deck planking, though!
I wanted as much deck framing as possible to show, but I still needed to accommodate three long gums. I started the holly planking at the outboard mortar pit bulkhead and worked my way to the waterway. The margin p[lank was custom fit. It turned out to be as wide as the others at it's forward end, with a bit of a taper aft. It turned out pretty well.174.jpg175.jpg176.jpg177.jpg178.jpg179.jpg
I wanted as much deck framing as possible to show, but I still needed to accommodate three long gums. I started the holly planking at the outboard mortar pit bulkhead and worked my way to the waterway. The margin p[lank was custom fit. It turned out to be as wide as the others at it's forward end, with a bit of a taper aft. It turned out pretty well.View attachment 251827View attachment 251828View attachment 251829View attachment 251830View attachment 251831View attachment 251832
Every place that I look I see only precision and care in selection of materials. You provide us with a very high bar of crafting excellence to enjoy every minute . . . or more as the eye leads me on. Truly outstanding in both your planning and equipment utilization Rich (PT-2)
