I think it is just a cover for the helm\tiller mechanism just in case the maintenance is required,One question: I never understood looking at such helm table - I this closed status the helm / tiller was not possible to move, because of the limitation of the front oval opening, which is too small.
In practice it has been shown that maximum efficiency is achieved with an angle of rotation less than about 35°.I'm not sure that the fragment you indicated was dismantled while on sea. I tried to "steer" the rudder on the model, according to my observations, the rudder movement in this configuration is 60º.
I like the double hull planking method, similar to ship kits, which makes thing significantly better. Question is how did you take in account the thickness difference. When you cut out the hull plates did you take in account this thickness change or not important in the grand scheme of things?
Greetings, dear Mustafa I have learned this from an outstanding Master Dmitriy Shevelev. I described this technology in my posts on “La Jacinthe” Schooner France -1:42 scale .Dear friend,
I admire your model. Congratulations, you are doing a great job. By the way, I would be happy if you could answer the question that Uwe asked a couple of months ago. I'm also curious about your answer. Thanks in advance. The question was about the hull planking;
Uwe asked that:
''On these photos we can see, that you also slightly chamfered the edges of each plank, or?
So the individual plank is a little bit more accentuated - looking very good.''
