Did you paint these?The ancient port of Amathus in Cyprus
hot water and a pkank bender.
Perhaps. Or just leave it in the water longer... It all depends on the type of wood and the thickness of the plank.Perhaps a little household amonia would help you as well.
I recommend using hot steam for a few minutesPlanking is slow but steady. Planks are to thin and not flexible... so I.have already wasted some material, even though I used hot water and a pkank bender. Due to the length I also need more than.one plank for its row. There are 17 rows on each side, so it seems I will use about 50 planks.View attachment 166252
never heard of using ammonia
Maybe. I not a health nut, but ammonia must be used cautiously. Ensure good ventilation and fan, both when soaking and heat-bending. I'd prefer soaking in hot water, reheated as necessary.My understanding is the amonia breaks down the bonds inside the wood that makes it not want
to bend. Perhaps a little household amonia would help you as well.
from todays Jerusalem Post website: "7th century shipwreck, Ma'agan Michael"Upper deck, or the bridge connecting forecastle and quarterdeck/poop deck, is done. Now is time to begin planking.
That said, appears to me that I have to explain that this is not the way a penteconter was build. On the contrary, at those ages, it was the other way around, It was build with the shell-first construction method. That is the planking was made prior to the framing of the ship. The frames were coming after planking. Of course here I could not follow this method so I proceed as the usual method frame first and then planking, that is the method that came later, after the 7th century bc.
For the planking there is discussion. Were the ships planksthose days joined together with mortise and tenons or if they were laced on each other. Although Homer describes Odysseus building a ship or some kind of a vessel, in order to leave Calypsos island, but although he explains clearly how Odysseus joins the planking, ‘’ he bored them all and fit them together and then with pegs and fasteners he hammer it together…” the various translations have produced a disagreement. In any case the laced method is the older method, that means that in Homers time most probably the new method -mortise-tenons- was used. Lionel Casson and many other scholars believe that most probably or even definitly, penteconter were build with the modern method of mortise and tenons. Also at the substantial period the laced method was mostly found in wrecks around Egypt.
View attachment 165141View attachment 165142
Yes it seems I got a typing mistake there. The frame /skeleton first method begins sometime after the 5th Century AD and not BC as I wrote earlier.During the 5th-6th centuries AD, 'skeleton-first' construction, in which strakes were fastened to the pre-constructed keel and frames, was used.
