Colin Archer RS 1 anno 1893
This a very interesting project - very good work and many thanks for sharing with us your way of solving these technical problems
I was lucky enough to stay with someone in the family today. Used 5 angle grinder blades 125 mm
had to buy with a small plane grinder also to smooth out the balls that you get with only angle grinder. Unfortunately, the motor on the plane grinder is a little too small, so I have to be patient. will continue to cut on the steel keel tomorrow
New weight is 7,5 kg
then I made a sledge in which the metal keel was placed. it helps when drilling holes for M4 mm bolts. it went with 12 pcs. I also finished the template on top so I have something to cut the keel after. also had to notice the underside since it is narrower there
That plate on top is only temporary as a template
underneath
new update.
has left a bit. so now the keel weighs 5.1 kg.
have some finishing touches to make it look the same on both sides. I've noticed how many mm I have to grind down. must also make a notch on the end of the keel. I don't think more will be done before January 2, 2020
