Hello Dan,Thanks to everyone.
Another small update:
I cut the planks from a maple piece. I want to leave most of the section unplanked and decided to just plank the area in the center of the deck.
The caulking is done by the "2B Pencil" method. It was easy to do and looks good.
After sanding and a coat of oil:
I also did the hatchway to the hold... at least a part of it. I should have planned the cross section to include all of the hatchway. Now it is "hanging in mid air" unsupported. The same will be true for the main hatchway and grating on the main deck
Can't change that now, so I will just continue and see how it turns out...
Anyway, I cut the pieces for the hatchway and the lap joints on the small table saw. The wood I used is pink ivory. I bought a small piece years ago to turn pens and thought it would be cool to represent the red color with it:
The rabbet for the grating was cut by hand with an Xacto knife and a small chisel. The sides are tilted 5° but it's difficult to see it on the model.
According to AOTS the rabbet was only cut in the longer pieces of the frame (coamings). A batten was attached to the short pieces of the frame to support the grating. I will try to cut a rod with only 0,5mm wide sides...
After clean up with sandpaper and oiled the color of the wood really turned red(ish):
... I love scratch building is because we always learn something from one model to the next.
Raymond
Outstanding Buddy. You are a Rockstar.Absolutely true! First thing I learned today was "never rush anything" and "do not use superglue again".
I took off the deck by soaking the white glue joints with a drop of water for about 5min and a gentle pull on the deck beams.
The hardest part was to get the pillars loose because I superglued them.
I treenailed the deck planks by pressing small indents with an awl and "filling them up" with a sharp pencil.
Now I have to go through my books and build logs in the forum to check the treenail pattern for the thickstuff planks. Then the deck will be glued back in place and the build continues.
For the same reason I am usually using only water based wood glueAbsolutely true! First thing I learned today was "never rush anything" and "do not use superglue again".
Hello DanAfter a little pause I can finally continue work on the cross section. After all it has to be finished when I receive the Trident Alert
Added a few planks on the lower deck for the sailroom:
And the main deck framework is done, glued and sanded. Now I can start work on the sailroom...
I rounded the corners of the main Hatchway frame:
Still have to apply oil to the sanded areas to bring everything back to the same tone.
