- May 21, 2023
Peter,
I applaud your decision to revise your Flying Cloud forecastle (fo'c'sle) deck to the correct 5' main rail molding height. As we've discussed before, the underside of her fo'c'sle deck would have been 4'9". Since you already removed her windlass you agree with the fact that there wouldn't be a ceiling high enough to work this device underneath. You clearly want to replicate historically accurate appearance based on these latest developments. So, I'm sharing my concept illustration of the Stag Hound fo'c'sle bulkhead using the Boston Daily Atlas description. Rob and I have concluded her windlass, as well as both waterclosets would be located 3' below the main deck. That means crew quarters would also be below. Since Flying Cloud was just slightly larger than Stag Hound her predecessor, it's not a stretch to consider her almost a twin to that vessel. Here's an excerpt from McLean's article proving crew quarters were set up there.
This final sketch is 1:48th scale, double the size of 1:96th. Inspiration comes from the front fascia of the stern coach house on Glory of the Seas which really was this ornate. Typically, Duncan McLean is terse when it comes to his descriptions of any type of structual embellishments. All we know factually is that the fo'c'sle had accomodations for one watch of the crew an in the wings she had waterclosets. Twin companions and twin ladders are common sense to facilitate crew movement. It's almost 30 feet across. Having a single ladder or companion would cause a bottleneck.
Of course, this is all conjectural but based on serious research.
) than anyone else on the forum. Respect.
