Canoe21
Lawrence
Hello John, Great work as always, more pictures.
Regards Lawrence
Regards Lawrence
Hi John,I was chatting with Brian and he mentioned he had built one of these kits, so I thought I would post my build log of it that was deleted on another forum,
I have put it in the kit section although it is mostly scratch using the kits castings.
This is a Euromodel kit of The Friedrich Wilhelm zu Pferde, I believe it translates as Fredrick William on Horse back, I started this kit quite a few years ago, and due to many things I am only just getting round to finishing it.
When I received the kit and checked it over, there were a few things that did not seem right, the four middle bulkheads were approx 4inches apart, which seemed to much, also when I dry fitted the bulkheads to the keel and ran a strip of wood along to check the alignment there was an obvious bulge where bulkhead four was, when I checked the plans and line drawings I found that they had drawn and cut bulkhead five twice, so after re cutting one of them to the size of bulkhead four, the strip of wood then ran fair, but I still did not like the spacing of the center bulkheads, so I decided to scratch build the hull with full frames, this was my first attempt at lofting and cutting frames so you will probably pick out a few mistakes, these early pics were pre digital camera so I only took a few because of the cost, see following pics,
View of the hull in frame. Luckily they gave a good set of drawings including the body plan and water lines, so I tried to place the frames between the ports to make things a bit easier, I decided on my frame thickness and drew the lines between the ports taking the lines down over the water line plans and with the help of the body plan I redrew the frames.
another view
Bow shot
Looking down on the orlop deck, I must emphasize this is scratch built, not boasting or anything, just want to make sure so you do'nt buy a kit thinking this is what you get.
Full length overhead
Transom, in hind sight the timbers are too large, wide.
view through the transom.
This was my objective to build a fully framed hull with cut aways so that you could see inside of the ship
The lower gun deck being planked.
In the top left corner, these parts make one double frame, and below these will make four frames.
Close up of the orlop deck
What a contrast from your ZHL RC build, wow your model looks great John.View attachment 24826
First job after the cleaning was to locate the positions of what was left of the cast decorations,
so I took photo copies of the areas that had to have decorations attached, I'm only showing
one but I did do several, this is one of the bulkheads.
The painted decorations in place over the drawing
Now this is what I mean about showing one thing on the plan and giving you another, big difference in size
and also with the capstan
same with the capstan
Now for the up side of things, these are the cast decorations for the lower beakhead, I think the top casting is from the other side, as it looks kinda flat to the lower casting, if you see what I mean, my mistake.
and sitting over the plan
Some of the castings for around the quarter galleries were not too good, so I made a casting plaster mould of a good one and cast some more in white metal, which the original ones are made of
Thank you Steve for the nice comments and all the likes,What a contrast from your ZHL RC build, wow your model looks great John.
Cheers,
Stephen.
Thank you for your build log John,Thank you Steve for the nice comments and all the likes,
best regards John.
Bonjour, je suis nouveau sur votre site. Je suis arrivé par hasard car je recherche le Manuel du kit Friedrich Wilhelm 1/48. Un voisin m’a fait un beau cadeau empoisonné en m’offrant cette boîte. Est ce que quelqu'un pourrait m'aider à le trouver?Salut John,
Sonne comme un kit Claytons, le kit que vous obtenez lorsque vous ne recevez pas de kit !!!
Belle coupe.
À votre santé,
Stephen.
This has been my first scroll through of your build log and work. Truly amazing in detail and quality. I really enjoyed your early revisit of the orlop and stowage along with the guardian crew members. An excellent show piece for your many hours well spent. Rich (PT-2)Bonjour, je suis nouveau sur votre site. Je suis arrivé par hasard car je recherche le Manuel du kit Friedrich Wilhelm 1/48. Un voisin m’a fait un beau cadeau empoisonné en m’offrant cette boîte. Est ce que quelqu'un pourrait m'aider à le trouver?
Un grand merci
Un grand merci
Only a fast off-topic here. Sorry JohnBonjour, je suis nouveau sur votre site. Je suis arrivé par hasard car je recherche le Manuel du kit Friedrich Wilhelm 1/48. Un voisin m’a fait un beau cadeau empoisonné en m’offrant cette boîte. Est ce que quelqu'un pourrait m'aider à le trouver?
Un grand merci
Thank you for the nice comments,This has been my first scroll through of your build log and work. Truly amazing in detail and quality. I really enjoyed your early revisit of the orlop and stowage along with the guardian crew members. An excellent show piece for your many hours well spent. Rich (PT-2)
