Not over heat----that would take a tungsten wire instead---I want to cut the wire with a dikes and maybe file the ends so I get a spark. A Spark is a lot hotter then just a resistance wire and will not use much energy to set off the charge. Like I said before I recommend the spark to initiate silver fulminate but if you want you can try to get the black powder to go with a spark if you like to experiment.
My feeling is that the black powder will not explode all the time with just a spark, that is why I advocate using a cap material.
