Speed of the build should not be the objective but being able to know that you are doing what you are able to do each day that we have. Rich (PT-2)OK A LITTLE MORE THIS IS REALLY BECOMING SLOW ALL DUE TO PHUSICAL PROBLEMS BEING IN A WHEEL CHAIR WORKING THROUGH THEM WITH JESUES HELP HOPEFULLY PROGRESS IN THE NEXT FEW WEEKS, SHOWING PLANKING BEING INSTALLED AND PARTS DRY FITTED I THINK IT IS PROGERSSING NICELY. GOD BLESS STAY SAFE ALL DON
Nice decking providing area for the ship's surveyor to walk about before going below deck for further inspections.OK MORE PROGRESS, DECK PLANKING INSTALLED STERN AREA NOW I HAVE TO FIGURE OUT WHAT I AM GOING TO COVER AND WHAT NOT, ACCOMADATIG BOT VISUALLY AND SHOWING FRAMING, ONCE THAT IS DONE NOW DECISION TIME TO TAKE IT OUT OF JIG OR LEAVE IT, PROBABLLY TAKING IT OUT TO WORK ON UNDERSIDE PLANKING. GOD BLESS STAY SAFE ALL DON
This dredge barge gets my mind working: loading is logical by dumping the excavated material into it by a conveyor belt or simple shovels full with each grab. . . but how is the barge unloaded. It would have to be careful not to damage the hull unless it moves off shore and has bottom hatches that can open and dump the load. I would like to learn from you how the barge functions. It is a nice build. Rich (PT-2)DECKING INSTALLED, END PIECE BEING DRY FITTED, NOT GOING TO INSTALL MUCH DECKING AT THE BOW JUST A FEW, AFTER CLEAN UP AND FINAL SANDING ON THE PLANKS ANOTHER COAT OF WIPE ON POLY WILL BE CUTTING FRAMES TO PROPER HEIGHT THEN ON TO THE SHIPS BOAT A MODEL WITH IN A MODEL CHECK IT OUT RICH FOR POTENTIAL DIARAMA. GOD BLESS STAY SAFE ALL DON
Now I understand the dredge barge better. I have seen abandoned dredges in Montana and Alaska with the massive fan sweeping arcs across acres and acres of land as the worked along and then when the deposit played out it was less expensive to abandon them in place than disassemble them to transport the parts elsewhere. Thanks for this very informative photo of the two in action. Rich (PT-2)@PT-2 The dredge disposes of its load by dropping it into the accompanying boat that Don was referring to.
Some more information about the small barge and the function you can find in the monographThis dredge barge gets my mind working: loading is logical by dumping the excavated material into it by a conveyor belt or simple shovels full with each grab. . . but how is the barge unloaded. It would have to be careful not to damage the hull unless it moves off shore and has bottom hatches that can open and dump the load. I would like to learn from you how the barge functions. It is a nice build. Rich (PT-2)
Wonderful how color in 3-D brings out the members that are wanted to be viewed. No drudgery in this dredge! Rich (PT-2)Ahoy!
@Don - The construction for the wheels is a separate construction that you have to make (GRAY COLOR in the pictures). This is not the frame of the hull skeleton.
View attachment 258684View attachment 258685View attachment 258687
I too don't recognize anything associated with a ships boat with these straight pieces. If the kit instructions or plan details don't show anything, you are on the right tack reaching out. Rich (PT-2)OK STARTING ON THE SHIPS BOAT AND I AM COMPLTLY AT A LOSS ON THE FRAMES AND WHAT I HAVE IN PACKAGES THIS IS FOR KRIS, PLEASE HELP KRIS, PICTURES ARE FOR THE FOLLOWING UNMARKED BAG WITH LOTS OF PARTS, FRAME NO 27 BACK AND FRONT I HAVE THE JIG SET UP AND FRAMES NO 3 AND 4 I COMPLETLY DO NOT UNDERSTAND AT ALL MY UNDERSTANDING IS THAT THE FRAMES CONSIST OF 2 SIDES ONE LONG CROSS MEMBER AND 2 SIDE PIECES BUT, BUT I WILL SEND THE JIG AND FRAME PIECES FOR FRAME NO 3 AND 4 LATTER, WAITING THEN I CAN CONTINUE TO MOVE ALONG. GOD BLESS STAY SAFE ALL DON
Now with the view of the flat bottom, like a dory, the pieces in the bags seem related but I have no actual clue. RIchHERE IS PICTURES OF BOAT IN THE JIG, RICH THE PROBLEM IS NOT THE FRAME PIECES AS THIS IS WHAT KRIS AND THE MONOGRAPH SHOW THE PROBLEM IS WHAT I HAVE RECEIVED IN THE PACKAGES THAT IS CONFUSING, NEED HELP KRIS. GOD BLESS STAY SAFE ALL DON
