HMS ALERT 1777 cutter POF by Uwek
Hallo Zoly,
no I will not
In the past I put some very thin (30g/m2) paper in between the parts of the keel (see f.e. the La Salamandre)
but due to the fact that there was in original structure no caulking between these elements - I will not show them.
It is a pure question of taste....... and seems, that my taste changed with the time ...... let us see how often I will change by taste in future ;)
Ok thanks,I might use pencil
..and now they returned together with mysterious marks and signs - I´m dazed and confused. I´ll stop reporting about bold and not-bold letters, better take my lunch and a drink.
In this post I will show the finalization of the main jig
There are two additional elements at the stern to be installed, later as a base for the frames
one side installed
Now the final board on the top - BTW: no nipple for the frame spacing is breaking when you prepare these parts - the board material is very friendly to the modeler and the laser cutting very accurate - the material has a much better behavior than plywood - maybe an idea for other kit manufacturer ...
on the top of the photo you can see the longitudinal stiffener with it six supports - on the lower side already installed
the top board installed and fixed with the clamps - not glued
the construction jig is finished
in the following several views to get an impression of this interesting and promising construction
All together a very interesting small project in the project - well prepared and everything fitted very well
The future will show, if the model parts will fit also in this quality ....... the jig was already promising fun for the rest
I have just finished the jig very good sofar I found easing the slots made assembly better
