Hi Uwek, good work and interesting in that you have the laser cut beak decorative insert. Mine is a carved boxwood version. Another difference is the fit of the ribs in the cradle. Mine fit more snuggly right up to the edges of the cradle perhaps because I did not cut the futtocks down. And your futtocks gaps are far neater than mine.........
.......... I have to say this is so far is a very enjoyable kit. So much different to POB and so many more complexitities. The work itself is not difficult but there is so much thinking required. ........
Thank Uwek for your detailed report. I found the join of the base of keel( 23) to stem part(11) quite difficult to align due to the curve and varying thickness of the parts.
Hi Uwe, love your new sanding machine, at the moment I am using a converted drilling machine it does the job but I would also like to
purchase a sanding machine. Looking at your photos did I see you sanding the frames at the angle, at this moment I am sanding frames square
then using a DREMMEL with a sanding drum to blend in the frames.
Hi Uwe,
How deep is the rabbet?
Mentioned in the CAF drawings, but as well in the ancre drawings from Boudriot 1,5 mm, so I tried to reach this depth
Then the frames fit on the keel inside the width of the rabbet? I’m having a hard time envisioning the assembly. Sorry if it’s an odd question.
