**VIEW THREAD HERE** |
Good looking copper sheathing
I wonder only about this relatively bigger distance - Is the upper end of the coppering representing the waterline?
Or is it the strange perspective making this? Directly from the sideview the upper end would be a horizontal line - but sometimes, especially on curved surfaces the eye is showing something different......
A contemporary model in the NMM of the HMS Bellona
View attachment 471889 View attachment 471890
AllanThis came up the other day on another build log. It was asked if the coppering was started at the keel or at the water line. I would not be surprised at all if some ships were coppered from the keel upwards and others from the water line down, both of which would have had overlapping. I had never gave this any thought before the question was raised and did some digging but found nothing other than the drawings by Peter Goodwin. If Goodwin is correct in The Construction and Fitting of the English Man of War, page 225 it would have started from the waterline and worked down, but again, I have no idea if this was the general method followed or just his supposition. It seems it would be easier to keep things square if starting at the keel, but...........
You may be right Mallacoota, and perhaps both top to bottom and bottom to top were used on different ships and eras. The only information I could find was from Goodwin along with a few photos which are below. Current plating on Cutty Sark was laid down top to bottom but this may not be how she was originally sheathed. If anyone has more information based on contemporary sources that would be great. Looking at the original coppering plans for Imogene at RMG it is not possible to tell if the overlap is from the top down or the keel up. It does give one an idea of the lay of the coppering though, so a useful drawing. For the Edwin Fox 1853, in the first photo below, plating was laid down water line to keel. I am not sure what ship is pictured in the second photo but the plating was installed from the water line down as can be seen by the overlap which matches the Goodwin drawings.Just thiunk of the plates as clinker planks,
