Ditto on the dittoditto
Amazing build Oleg, it’s an inspiration!!! May l ask what kind of wood do you use to fill the gaps between bulkheads?First I installed the nightheads and plenked the beakhead and forward part o the upperdeck
View attachment 216091View attachment 216092View attachment 216093
Hi Oleg,
everything is quite simple, cut to the middle with a wave, then push the mold apart and cut to the model, the halves will always correspond to each otherHi Oleg,
Wonderful work, as always. One question for you. I've seen many different ways to register each half of casting molds, but yours has me stumped. Would you please explain how you created the "crinkle" looking patterns to lock both sides of your molds.
Thank you.
www.belmontmetals.com
Thanks for taking the time out of your day to provide such a detailed answer Oleg. I have done some trials myself, using Max Mold 60, but always looking for the best solution. The reason I asked about the mold material was in your second set of photos, the mold material is white. Max Mold 60, as you know is red/brown. It seemed to me a little "chalky" to cut without some crumbling. But now that you've explained how, I need to do another test.Hi Ken, yes, I cut the mold into 2 parts with a knife creating a zigzag pattern.
This was my first experience and I actually messed it up: I did excessively big molding boxes. It's only when I started cutting the molds in 2, I realized my mistake: the modls were so big that I was not able to cut them. So I had to cut off the slices of mold material from all sides to make the mold smaller. Unfortunately, because of this, subsequently I was not able to put the mold back into the original mold boxes to do the casting. Usually that's what you do: you put your mold halfs back into the box where they were created and close the box. Since thi is the box from which the mold is coming, the walls of the box perfectly match the surfaces of the mold, so you will never over-press the 2 parts of the molds. In my case I couldn't do that, since my molds were now smaller than the interior of the boxes. So I had to clamp the 2 halfs together by other means and as slightly as I could, but still firm enough. However, in this way it's not possible to completely get rid of the slight ovality of resulting castings. It's not catching the eye, but still it's there. I know it's there.
Oleg, electrolyte should not be used, it is harmful to health, food vinegar 9% is quite suitable as a substitute.To blacken the canons, I had to do the copper plating first (electroless).
For that, I used the solution made of distilled water, sulfuric acid and copper sulfate.
All 100 cannons are done and I started installing them on the ship.
Yuasa Electrolyte Battery Acid
Features: Easy to use single use packaging Clean: no mess Prevents waste of good batteries when electrolyte is lostfortnine.ca
View attachment 395133View attachment 395134View attachment 395135View attachment 395136
Ok, good to know. All the recipes for copper plating that I had found on the internet, were with the acidOleg, electrolyte should not be used, it is harmful to health, food vinegar 9% is quite suitable as a substitute.
Hallo @TotmozHi Oleg!
I've done etching before with the same problems. Now I just ordered laser cutting.
And the model is great!![]()
Happy Birthday, Oleg !
Oleg, such a beautiful model, great workThe story with guns is finally finished. All of them assembled and installed on the ship together with carriages and equipment. Port lid tackles also installed. I made a set of photos to reflect the curresnt stage, since the hull is almost complete. Only decorations are missing, and a boat.
View attachment 401224View attachment 401225View attachment 401226View attachment 401227View attachment 401228View attachment 401229View attachment 401230View attachment 401231View attachment 401232View attachment 401233View attachment 401234View attachment 401235View attachment 401236View attachment 401237View attachment 401238View attachment 401239View attachment 401240View attachment 401241View attachment 401242View attachment 401243View attachment 401244
