ONLY of I forgot something REALLY important, like the tiller, or the Captain's seat of ease.How true!
True storyNo chance. If I finish the outside you'll just think of something to change and rip it all out...
Oddly enough, that’s exactly how I do it. That way I don’t have to worry about pencil lines.Started marking trenails on the deck today. Masking tape makes a good guide.
Erasing pencil lines without obliterating the trenail dots would be a huge pain. The markings aren't the most precise as in other master modelers builds, but at this scale they are close enough. Plus, this deck will be covered over and only visible with a borescope or by peering in through a gun port.Oddly enough, that’s exactly how I do it. That way I don’t have to worry about pencil lines.
But I use a sharpened punch to make a tiny holes along the edge of the tape.
Makes sense Kurt!Erasing pencil lines without obliterating the trenail dots would be a huge pain. The markings aren't the most precise as in other master modelers builds, but at this scale they are close enough. Plus, this deck will be covered over and only visible with a borescope or by peering in through a gun port.
At 1:75 scale (DeAgostini claims incorrectly that this ship is 1:84 scale), the trenails are so small that even these pencil marks are still too much contrast compared to how they appear on a real deck. If they fade a bit before applying spray varnish, they would look more realistic. Wooded peg trenails would be many times larger than real trenails. Most modelers still use wooden trenails because, as modeling can be considered an art form, making them demonstrates the builders understanding of the parts of a wooden ship, despite them being oversized. I am leaning toward realism instead of an art piece, so the trenails have to be very small. It's up to the modeler to choose the appearance he desires.Makes sense Kurt!
I use a punch to make holes. That way I have a few options. I can add wood treenails, or use putty to simulate treenails, or I can let stain get in them and darken them (similar to marking with pencil).
Agreed! I used a punch on these and let the stain enhance them. They are barely visible at a distance, but very noticeable the closer you get.At 1:75 scale (DeAgostini claims incorrectly that this ship is 1:84 scale), the trenails are so small that even these pencil marks are still too much contrast compared to how they appear on a real deck. If they fade a bit before applying spray varnish, they would look more realistic. Wooded peg trenails would be many times larger than real trenails. Most modelers still use wooden trenails because, as modeling can be considered an art form, making them demonstrates the builders understanding of the parts of a wooden ship, despite them being oversized. I am leaning toward realism instead of an art piece, so the trenails have to be very small. It's up to the modeler to choose the appearance he desires.
The effect your trenails make is better. Tell me more of your technique, describing the type of planking wood you have, and the stain and putty you use. Your deck has more grain contrast. I may want to use this on the weather deck since it will be fully visible.Agreed! I used a punch on these and let the stain enhance them. They are barely visible at a distance, but very noticeable the closer you get.
Thanks!The effect your trenails make is better. Tell me more of your technique, describing the type of planking wood you have, and the stain and putty you use. I may want to use this on the weather deck since it will be fully visible.![]()
Ramin wood? Where you find that? Here is what I do for decks.One more thing about the deck. I prefer Ramin wood for decking, because it has a tight grain that looks very nice to scale. Beechwood grain is more random and doesn't usually look that good to me. So I want to try Ramin wood using this technique on my next ship!
Here is a pic showing the wood as provided in the kit (bottom of pic), then you can see the wood above it has already had some light sanding to spread the charcoal. It doesn't even look like the same wood!
Then finished below...
I get Ramin from the hobby shop, Ages of Sail.Ramin wood? Where you find that? Here is what I do for decks.
I use tanganyka wood, usually supplied by Corel, in 4mm widths for 1:75 scale ship. I usually cut 82mm long strips and stain one long edge with a brown Sharpie marker, then use a jig to mark the two end trenails with a 0.5mm mechanical pencil that has brown tinted lead in it. The deck is scraped but not sanded, because
I actually do not want to embed the pencil graphite into the grain and gray the wood. Spray Krylon Satin varnish is all I use to coat it, trap the trenail marks, and bring some of the color out.
And now…the dots are eyed…by us!Tedium is OVER... for now. All the dots are... dotted. The frame edges of the gun ports were also painted to neaten things up. Added a light coat of Krylon Satin Finish to lock the dots down.
