Hi Bill, How you doing. Thank you for your kind comments I will try to answer you questions. I have had many occupations in the past, from working on aircraft, metal work, building work, I made a 70ft narrow boat from scratch in steel, which I lived on for 10 years. As I said this is my first model and getting used to the small size of everything is a skill I am working on. I have a wood turning lathe on which I enjoy making bowls. I have a metal work lathe and a milling machine, planer for wood. All are too big for models. I have a dremel drill and stand which I used for the amunition racks. I set up a stop clamped to the base of the dremel stand to ensure that the cutter would always be in the centre line of the wood used for the rack and made a mark on the stop/guide at 3mm from the cutter which is the distance from centre to centre of the holes. I used a ball burr that came with the dremel for the holes. I used a much longer piece of wood than was require. I made the first cut, with the depth stop set, and the wood up against the guide then moved this hole the the 3mm mark and made another cut. I continued this for about 40 holes then cut the wood to the size I required. Then rounded the ends. As for the glue, my experiance with CA and wood is that CA soaks into the wood and sort of stains it and is very difficut to sand out. I have only used carpenters pva glue by Ceys on the model. It is fast drying, only 5 minutes. It squeezes out everywhere, but after about 10 minutes it is still soft but not sticky. I then cut/scrape it off with a craft knife. I don't sponge it because that seems to thin the glue down and push it into the grain. This is obviously not a problem if you are painting your model, as I am, but an issue if you are varnishing.
