La Renommee 1/48th Scale
Thanks Grant - the product does much of the work - the Liberon Finishing Oil is easy to use. Like most oil finishes it requires wet sanding. Shellac is a bit more tricky as it does require proper brushing technique to avoid drips and puddles in the corners.
