Hello all
A very attractive model, but a rather difficult kit.
![DSC03202.JPG DSC03202.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353371-78da0b8db423dff809930b48cf133783.jpg)
First of all, I assembled the jig, but the board was bent.
![DSC03203.JPG DSC03203.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353373-5f94d438af94459c0e650d7164469db8.jpg)
I was able to fix it without any problems by pasting it on a 1cm thick plate.
![DSC03216.JPG DSC03216.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353374-96c2e39963dd3f71e60a87ae2d08036a.jpg)
The frame is as easy as sticking two pieces together.
![DSC03204.JPG DSC03204.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353375-b232fc8da807073d5f32b93c2ea04a5d.jpg)
There are a few parts that are not laser cut perfectly.
It is necessary to cut so that the frame is thin and does not break.
![DSC03282.JPG DSC03282.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353376-545fae490e4b862a64fdb0b30744a2af.jpg)
Frames 1-22 are No 1 in the front and No 2 in the back due to the bevel cut. Frames 23-44 are number 2 in the front and number 1 in the rear.
![DSC03207.JPG DSC03207.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353380-0ce459e774d64b310de958fc2e34b2e1.jpg)
I use this router all the time to remove laser cut soot and bevels.
![DSC02986.JPG DSC02986.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353381-8c417364e6783f6fc6a77bd2a16dfba5.jpg)
The frame does not fit in the jig and keel, and it is difficult to adjust the meshing with a file.
![DSC03219.JPG DSC03219.JPG](https://shipsofscale.com/sosforums/data/attachments/353/353403-ec52d143b62495097463e139b6c2b49f.jpg)
