- Jan 9, 2020
And it is exactly that "microscopic" part which precludes me for attempting a build like this. Hats off to you, Vladimir.Thank you Marco. Yes, it's realistic, but microscopic![]()
As I know - at the moment the export version is not ready yet.My question is how can one obtain the kit.
Are you building the pilot version? What would be the difference for an export version?As I know - at the moment the export version is not ready yet.
Dirk was first to answerAre you building the pilot version? What would be the difference for an export version?
Good morning Vladimir. Good to see some more of your work. That is a lot of oars. Did you make these from a length of wood on a lathe? If so do you shape the blade of the oar last? I have some to make later and am interested in the process. Awesome work as always. Cheers GrantIt's been a long break, but it's overI added more small metal details in the bulwark and spent a lot of time making the 20 oars.
View attachment 366790View attachment 366791
Good morning Vladimir. Thanks for this. I appreciate the help. Cheers GrantHello Grant and thank you. My technology is a bit different.
1) The oars' shape is laser-cut:
2) First I remove the excessive thickness of the shaft and the blade with sandpaper, and form the blade's profile.
3) And then I round the shaft by hand with a knife this way:
Since I'm afraid it's too thin for lathe (only 1.5 mm). The same for the handle.
