Very interesting and impressive model. I’m fascinated by the method to rearrange the carronade from the bow, to midship, to the stern.
Jan
Jan
Good morning Vladimir. Impressive modeling . Your gaff is perfect. Cheers GrantAfter some thought, I decided to make a new gaff using residual wooden cuts.
And next - another complicated part, which are the bowsprit bitts.
View attachment 369845View attachment 369846
Hallo @WalteroneView attachment 347120
I'm starting a new project, it's a brand new kit by Master Korabel, released in December.
These boats were part of the equipment for all the 1st rate ships of the Russian Navy in 19th century, not only the “Twelve Apostles”. Launches like this were used for patrols during the defence of Sevastopol in the Crimean war (1854-55) after the sinking of the Black Sea fleet.
The kit allows you to build the launch in different versions – with or without rigging, with oars or under sails, armed for a landing operation or for an expedition, and so on.
My kit is an extended one, all in pearwood and with ready-made sails.
For framework assembling this kit provides a 3D plastic jig, instead of a wooden holding frame. As you can see, the model correctly copies the real boat's construction.
The carronade is metal-cast.
The sails (only the reef points are missing).
25 pages of various schemes and specifications.
To be continued (after the start).
Happy Birthday Vladimir. Hope you had a good one yesterday. Cheers Grant
Good morning Vladimir. Metal work is something I just struggle with so I will just watch and admire. Excellent as always. Cheers GrantGoing on with the masting, added metal parts. The main mast is not assembled yet, because I want to attach the sail first.
View attachment 372322View attachment 372323
Some of them (eye-bolts, hooks etc) are photo-etched, and the others (topmast cross-tree, bowsprit cap etc) are metal-cast.Are these made out of white metal?
Good morning Vladimir. Those are really good kit sails. I am assuming you added the bolt rope? Cheers GrantThe ready-made sails are part of the extended version of the kit. I slightly coloured them with black tea to create effect of an "aged" material. And next added reef points.
Hi Grant, thank you. No, the bolt rope was already there.I am assuming you added the bolt rope?
