Le Rochefort
And the next two frames, 29 and 30 are started: I cut out blanks that correspond with the plan's futtocks. After gluing them up, I rubber cement the frame template on. After drying overnight, I first cut the frame out at 90°, then recut at 20°.
Hello mwknoop,
Well done!
Please note that the middle two parts of the keelson (i1 and i2 on the plans) are wider than the other parts of the keel.
On your pictures it look likes it's identical to the rest of the keel.
There is also a post here in the forum about this topic:
Looking forward to follow your build progress
Very nice frames, I also made No.1 three times. The first one failed, I got the wrong board with a thickness of 4.5mm for No.2, only the third one was the right one.
