Le Saint Philippe 1693 after Jean-Claude Lemineur (Ancre) in scale 1:48
Wow. Just….wow.
Thank you, my friend. Taking out the rider frames and some of the platform beams didn't feel like a wow moment but I had built myself into a corner. Now I need to figure out how to build myself out of that same corner in the weeks ahead. It sure would be great if I knew what I was doing!
BEAUTIFUL, so neat and clean!!! Your fitting and checking the lay of the beams before fixing them in place is very well done.
Love the update Paul on the deck beams- enjoy your holiday -she will be waiting for your return !!!
Thanks, Chris. As you know even the mundane tasks take lots of time and demand precision if future steps are to be met with success. Case in point - the most aft deck beam located just below the wing transom isn't installed perfectly - a fact that has only now come to light as these deck beams are being fitted.
Well, that can't be fixed anymore so onward we go making the best of it...
It is so easy for us with our calipers, micrometers and macro photography to see something that is 1/64" off on a part that's 6" long and weighs 5 grams. Do you think the shipwrights of old maintained that kind of precision on a piece that was 24' long and probably weighed 300 lbs? Of course not. If they later discovered that something was slightly off, they simply made adjustments to the pieces that attached to it and kept going. Don't beat yourself up Paul. You're simply adding the human element to your build. Not many people here can build to the same quality as you, and when you add the fact that you only have a couple of models under your belt, that list gets much shorter. Enjoy your vacation, my friend!
Thanks, Russ. If mistakes are the measure of humanity, then I am more human than most ROTF.
Only you would know (if you hadn't told the entire forum) ROTF . Either way, I'm sure none of us would have ever been able to detect this micro-difference!!
Enjoy the holiday! She willl be waiting for your return, looking better than you remember...absence makes the heart grow fonder, right? You'll realize what a gem you've created when you see her next.
Believe me one of the hardest things with this hobby is when to move on even when you've made you know you've made a mistake. If there's little to no impact on the future structure and its too risky to correct - move on ! In time it will fade into the background and no one will notice it anyway.
Thanks, Brad. We're looking forward to some time away.
