Le Soleil Royal, vaisseau de 104 - De Agostini - by Jack Aubrey
Saturday, August 2, 2014
I finished the installation of all the guns on the open decks and, in addition, some other small detail such as casks, more pins and coils of rope.
In particular, I secured the four guns of small caliber (2 on the forecastle and 2 on the intermediate quarterdeck) in a different way. This method was often adopted for the smaller gun pieces when the ship was at sea and not ready for military action. In this way they were less bulky than the traditional method, even if less "safe". In fact, their use was almost always limited to the smaller pieces.
y4moBHPSBgS9O5UQ5h176mXZmBO9_82QLWXNLyWzOxlwmmUdxhmZ8Rf64uLoxYqtCTLPTsnNwvyvXSoOJbBuCNiy7JBeDsC1147MLIQHrtI5zSTuk7Pcgztit3yuOru6GdaCoI-s8wzO3BwtseJn2jq_aTkPT9mOJz7uOiXZBT_JcPVpf6qSTtccihtli6Bufl0MdQ_-tWg5AvwJyN2ZL6_DA
Here you can see the last decoration that remained to be fixed at prow: the sort of caryatid with human head and upper body, which legs transformed into a sort of column, fixed between the cathead and the "serpe". It was glued with epoxy glue having realized that the contact points for the bonding were few and rather small. However, with this glue it is attacked rather robustly.
y4mkgg6IpN3Qhf-dwq58lrzAkDZtxQxY_f23qgHAeOdbVglUPPgnfiQ-wt5sBigp2xJUD2moHl8iVCsZW7Ab1hj6n1KWvcEgUHEpGE9amsjXUqr-t4JdxUkIqBljC2xI1tHugx8SXI86Prh3qGltgbn-FfCF0_0uitrF1G_7co0SyCTvfPXw2xglt3Sr6ZIYV6BwZDJgz6nzJH-fTbIgON71Q
Here are shown the eight guns on the "lower" quarterdeck.
Unlike those of the forecastle, here the guns are all of the same size. There are also a couple of barrels, for the moment only glued with the need for additional work.
y4mea7TG4BWRoEQVmaWJUTawH4RdvG110yK8e4YO8jc7L4ovBA4vb3PYn2Mn8NhtvHxCiz0cKfEE7tkSBti5o16cQKPX0n92TIptD8mzDSD0HSYKcistqVX0lbtvm_ZaOWiM4RTnAKUBBrUpsmBJLV3C9qLDGF9kFuVBnZiQ3kFwH4bRJqVKLT2Wv82N7uXxSAkYWtCQ98MsV4Lc39x8EOToA
The other two light guns mounted on the "intermediate" quarterdeck. rigged as their two equivalents on the forecastle. In addition, there are two "seats" I think for the exclusive use of the captain/admiral and officers, in this picture you can see only one of them because the second one is hidden by the ladder.
Again, as I have often done in the past, I remember that the color of the blue paintend elements is much altered by the use of the camera flash, in the reality it is much darker than it appears in my photos.
y4mZtyiSabFYiPdMcNB6ahMGSt7RmoR3OpClwl_FEPQVmXS6PSbSPee9wuMDKgEhD1DElHB0LIn2u1F10BXGggrLepttxNmpVJiigfo140iUOQAkh3ftzcF9VFnEC0imeZtx-Wt3G__h6ETpkssLUIToQ1PtkMYjCDLV69Os9h9vO1p9FcHbPc_h4YdCoTOzTV5NIe0RpjlfCftNC7P7OZXZw
The central part of the upper gun deck. Here now there is only to fix the boats: I'm definitely considering to use a pair of pins to secure the support structure of the boats without having to use glue, leaving them removable.
y4mZLTwJPYS3w09W5p-wImoKzniB_E-sAiNMr2wFp9DGSooC-kFgoIvW2cGReKJ99gRnk_Uphu0KoyNtU21AoY6BwOjM8t_VUTJMS3gIDajNajjvtnyFE7b1SPkx15_7wMbVcKmo9vgLVNwNh8kcmlhaued3LUwOs8tLhMAUkSIT4r3MHu9ZO245gyNsevw0tc8cRtDQ1YMtLzN6VP2FGFzdA
More pictures and comments are coming soon. That's all for today, Jack.Aubrey
Thursday, August 7th, 2014
I'm installing the anchors, perhaps the last work of a certain commitment that still remains to do. I'm still missing one anchor on the right side and then this task is over.
After several attempts to build a decent cable with the ropewalk machine starting from far, attempts that have probably identified and highlighted the point of maximum useful usage of this machine, I folded up a simple solution: I've used, on the same machine, a traditional lanyard; that is, a larger starting base and it worked. The only drawback: the cloths. I removed this annoying problem by impregnating the cable with the vinyl glue very diluted. Once dry it was a bit stiffer than they should, but gradually I made it suitable.
The color is a bit off but maybe that's okay because if the cable was immersed for a long time certainly did not have to appear as if it were new.
Regards, Jack.
y4mUrUTJkZJUD3HI7v9mXFq1_B5GKtqT-3ctX16Qg_s8a3qsDqEETvwpieD_EoYad9504ekAF_FHjYS6C4U0IYDL6Mfq1tF_XzGZoRh_J0pzteEPOle7hVRxM_NZx7PTR25pOjkQG-AkYgTOlBHjweLAS0PGCscn-zKx_6Mve9sEjkeNw9I7Lk5R4oIIqJFv5huQ1mSZQfCYHs-Dju0Ohfhig
y4mOH6oMfTI4vlmIrv6f0xQagFMJff13zk8ZHFJCO6X816sB8_t4fsw3WGCDV8F00VbUt2_uPitXkptcXUiTlqwUgTM1KXs_TP4ZuKHme7v-I2n55XQvC9_OMiteEnChYiFsFHmofxKZX5y7MjE7HPvwON7nINyZn672jJxpj5NjwUa_DJunTLBvB3ZIJrV-p4kHXjgtIXKUHpcFKw9b5V8XQ
y4mVBLllNAvtCRbmG1jblSslA5TC7M9KGFC10W3vUQqh9CQ7i6LSGAejETv3m8q0SLKprpHu6Q_pCbZ65ubyRl7I3s7y9owTNI3UTw2U7bk7sDu_udVdEunxiZ_2wmsOFd1OO_Vf4DjaW1mfGXi1ICejRwn4D75j8VyV5q2Lc8Gg4-Ain5_wt-2KKcEjnhGx8Pp8lA1xG0bD3Rhg7U4zlQSFQ
y4mbeYZwZ3H49wiq5q-ESzUNw7aqTpNyGCPMY2hSc3Q96k1Q-A-3QhkTCNrKFmdX6ViMQj396no6CS3uO9ExMrbxVRwsDOdyp916jCWH0BcoT7WLX_wage8_74kvFkrs4djrxcJ7WLs645aS_t3zM_zmL3P5qe8hwGGO7rlOCvIwoyTGsnzIu0Cg-asuEwDt5BgvEQn2diU9fSauCiu7qtPHQ
y4miNOwDf7x83-m1VN2CtLsKBXUgmZlBGRl0EEmHe8NqUIk7vVAZhQPF3z7xJYCrFnTbHacmxX5DQJXPpaNXmRAvEVcXFAjNcgwoVF-iLoKGGEfoGRSeD7-U1NGVFhvdAqpeZ-Z8lGan4XAi7kncsEhJaY-uSjONX9vnDnMFy3cFRsdWcUe9a5iEGnjLlHNvr3yt5fr-Ucdwcq62Q56fwOIpA
Friday, August 8th, 2014 . .
Soleil Royal Launched. .
Today I did the last activities around the Soleil Royal, and towards evening, I realized that I had really finished the model . .
After 1550 days from the yard opening, back in April 18th, 2010, now I can finally say: "I'm done" this model.
Below are some pictures I publish here but I want to limit myself to only five. I proceeded instead to open in the site the album "Jack Aubrey's Soleil Royal"
>>>>> https://shipsofscale.com/sosforums/media/albums/jack-aubreys-soleil-royal.50/ <<<<<
where I will publish all the pictures I shot and that I'll shoot of the finished model in the next few days. These images can be downloaded at the original size.
So with this message, I am going to close this endless building log.
However, I'll continue to follow it in case of further comments/messages that will be inserted in the future. Thank you from now on to all who were involved and who have followed me in this long adventure.
Now I will take a couple of months as a "reflection pause" even if I'm already at work from now with my computer and CAD software to design and plan my next model.
A cordial greeting, Jack.Aubrey.
y4mDx2BZV8RkrWxo2NaDodWkes91wEsK8n2tONYucdFVe8g51bLr80hfJlQlnhj3Ligy9BZI55mZ5YeCws_bMZtrwuhhq2CZSKaQf86gaiSJUPgrbt4D-TCAQX1ri7Searo0CyIOvb0QNBpPaECMxzLkOHInSclHuMZkAoXrNPVAsYcsPG0ZJbMocgx-S4ZhR4ZAnFiAIEUMn_DY1bYfsyhnw
y4mSeUQbvvjeABp3fodSspR7gXQwnX182Bt1XHjUmp8e2ji7DX1_EgISmNLj_O_dhwpx0e4RbK_JmkA_byoH0aXQh0qirM6-tY2WaaAweIvFZT0A7BWn_DbNHT3QKjL3zMnZXD3qlpiKLtRCgRl9J-_IgM9jGYc13-QmOpTgrzi60DlH3cEg4LfdKFt_lZiWG4c6nFSssl8fb3SlpYL8KxKhw
y4mD-9UZ27AKN7BhruvJ735otS6D8Z00VCToikAOMOdLNJ9VwfSIoK13kajPbdY8sX4WUPV0U7P1sfdXpOZ5rVgSFDVEmHTJ1K8-rAiidTSEpsVla5L0E3q31oMmeFrJeXLoXoWorERe-Q6HOfQi6DPDrhxnN425EEnIpOcWBkgcGhcNCu487W1_vVTnkayQtNG38QlxNwhUFuJrPCH5a3toQ
y4m_kg3l6Fv1hOry373od1Rq0OF7Y1wG8Z8WYkSlxXE8Uwvu_Eyk8Tb7Yb3zkHECU_-PpsfNVCkI5I1CS9jafFEWtjRisATbapIR7G_K7HKNwXTH4s8T4D9Nk5uWwAdd0lK8lvjoVbucyVOk_slw0OboBYIIK3gtb-HlDcbKU2jkk_Dt3A4pLzRbTSueagzZ6POzOwEBXFzoABtHlx4i80m4Q
y4m3FdGpHO16pEYVSZluznNvRghWMUuDPT48t6mxYBRPvZQPJoUIiPjUGfOQTO4HcSRLYeBAzxQbr9kbty47VMWYdYRgI1zn6hqIatueWI1k8S_4uvrqD0XeUnBH6K5hC6WaiRf67CHEP853Quv28Rhr8SkeSG9xDLvvYv6_QfUnv16LjLMwHkO04Wxccc7rcWXyEVqD7dGyKkGyjCbFqC3OA
