Le Soleil Royal, vaisseau de 104 - De Agostini - by Jack Aubrey
Sunday March 4th, 2012 . . "Pazienze" and "Cavigliere" (until I'll find the proper english term)
The building of the "pazienze" and the "cavigliere" raise another interesting matter. Infact, the vertical elements of these details, in this case a 5x5mm wood strip, must be "carved" to receive another 5x5 or 2x5 strip. The achievement of these notches is not difficult to do manually, it needs only some patience, but this time I wanted to find a different path to obtain the final result.
I'm slowly but relentlessy discovering new ways to use my Proxxon table saw and, for this task, I found another way to use it just to realise these notches.
The next image shows a trial made to achieve this result: I positioned the height of the saw in order to protrude only for few millemeters and, by passing the table above I made what you see in the image. Obviously I made several tests until I learnt totally the lesson, with some waste of wood.
y4mBG-ugDvsNbEuqW1oPsW41RTLcHUEyx1DuuvJrDSVME3Tja4ZMrnhSUI9TAVEYRREj8oxU7ondiIj-RyDAhpbMaew54jWkci338763WSZljmAOXeI-o3nN9DXSlWH-dF5kNDnZBRwGxI-OYEnorHCh2cR6GLoaakASPgcZ9W238i2Atgf9lzZffrJYJTkSiYqUwQIJra7q4jNOPY8Cy6qow
At this point of the test, I went forward to the next step: cutting the 5 x 5 square strip. But this is a normal use of the saw . .
y4m14fdgnoOm1smiFTr7OOJxjli1_ySdQHBgfwQGO38-HYHY04nwXBis-pIr_ixq_X33vno9eR8ydT9SG0sS_HsrnOGRaN_-BCj6ZTP5G2GOnoJskbwVDnpFR6N0OQf4pZ9RVAsa34VDY_8B_BEzT25VJUgy_NC1_QsUiwb7_3xUg8MZY5vzJXIkMWfARGwt7WpJqZR1qCNgoIR2pCYBSeeNw
After these preliminary and successful tests I started to do the real work with the proper wood and the result can be seen in the next two images, the first with the wide notch for the "pazienze" and the second with the narrow one for the "cavigliere".
y4mGEGh0w9gcfQAD27si_1i4Hj3oso3dqDClYwLEeo7r-PpEVzQrIha9CzdbnnRX8ILU9Kolq2xJ_R-EE_DZfKt3nH29Hf6i8PD1FbSiiXXYpywIeccYnWiq-y7toWjYjgEqzIJxgpW1qODarpwZZwCUzKu_gLbmceMYsUW9X5N37xl8_EPTDy9PTnxaOmLSAQ5QC90pUznFu0W7IXRndlxcA
y4muSQt84kdPfMmz1geK0e6Qvah7XUOELfAYcxvJzLZx24adrrY5gaoKKPAVeYIUBnTfyDJtRwLc0CaaRN0PVdd27udgF0ccWctsG_vwWlKodc823fTFd3KbDzBjZkZPQWAMLaLjxKbaqbxmLSNSJqmDCZ6Mhd7WBrQoFa6jqvyJINF0KweDb-08pOP6EzBm5-Ksxiv-Qwo-ev8VLBOIC7qtw
Obviously they are not finished at all, I have to carve the head in accordance with my last message and cut then to the right length.
But, again, I'm very satisfied because I made a new experience with the table saw . . experience to achieve step by step, error after error, until the final, successful way was found . . next time this experience will be ready for reuse in my mind.
At this point someone will probably asks by himself: and the guns ? They are still in the process but, having in mind the same experience with another model, I know it is a boring task and so I mix the work on them with other more interesting activities like the one described in this message.
See you next time, Jack.Aubrey
hi Jack, The colored stain can we order them for delivery in the USA, very interested in thes do you have a link to the company. THANKS Don
Hi donfarr,
I bought that stain many years ago and I do not remember where I found it.
Anyway it is a product that is sold by an Italian company and it is also sold on Amazon.it. Probably you can find the same on Amazon.com or somewhere else.
It is a very common product, with a very low price and there is a water version and an alcool version. If available, the second should be the preferred choice.
Here a link on Amazon.it : https://www.amazon.it/s?k=mordente+...vqmt=b&tag=amamitsp-21&ref=pd_sl_6kept0afjw_b
Hope helping you, Jack.
Monday, March 5th, 2012 . .
Today I built a "strange" structure (never seen on the naval achitecture books neither french nor english . . ) that has the role to support the ship boats. It will be located on the upper deck, just over the gratings of this deck. I had to built this element because, without positioning it over the deck, I can't identify the right place to install the ringbolts for some of the 12 guns. In fact this strucure interferes with them . .
Here below you can see the boats supporting structure: it is built with 5 x 5mm wood. Again my Proxxon table saw had a key role in cutting the single pieces, giving the warranty of perfect cuts at 90° that helps very much their assembly.
y4mH2hUMUQSn46p9DPD4Vf5tOij8XJzx99pMYLjVTjpmERIkgeb6Y7gVD1UBqWtKBlOpUV9dUpFlvBSjZcV0Ny0Rpjop6Q7TzlsX41UD1H1XXOYsYFXGy-fpInBe_jLj8_jREnaxu8HRiHsqYwkWf8RZIdeq97MrDTkWLhbUwlRZJFMJbMBbOwf4pRBdNkYYU6Ibu5hjwtCzsoEbRfLRJzfFQ
y4meYqkYoYjgPE0DTZF1bxnWxiXNTGMB15-UIFgYalvvsslNf0iESpwT4T7FJR7lYez-awblUW_TlGio1BPTvl1NE-D-_0GcWfa0rCWCQio71X3y_dbzQpfy7rXPZ8dPaakgpBkAGVIdkWj8C4cU5DtY00P7Kh828zMvg6oJZTO2fpN1581pUXAW0BkF_5_t-d22OszOzfc9lpA5JOyxfj69g
Later I passed to the gun's trucks by painting them with red polyurethane enamel. I used a double adhesive tape to hold the trucks in order to paint them in a more comfortable way.
y4mFVjVpVQSQDviIKBAWxTfWc7vQC7qlkdyEI2am3HfNLQJnAxbNPnaI3cqXzjQHBXOJEdFx6gD39TN19SbyFf2C33BxmObmMm3127lSG7HEZeMEvA3RvzPdLTRSyfAZq_NnlQ2Dx-Pf-I9gr4uTQ8qPcFDvVHxoE8r2wZZPGAOPiWd25iwjkh5AllIBnbseAqO-zPlEX8XU1nuyoKemziMvg
Here below the trucks after the first coat of paint. It is surely necessary a second coat, may be a third. I'm seriously considering the purchase of an air brush. I already have the air compressor. With an air brush these tasks will be surely faster. I will see on the market . .
y4mc5fAQri0CP8dVxr-PQg2g6EtVJHNHF0mMSbbAwuydxMEkYTAtINL3gmi78uuQbUW_gKMgR4DEqFGNz6Iv7tM6TQbNH-Oc8e6t5F-hnqxwjWhNNXegIsO7HJvpz_lLinDpdWbyqV6j_h6GSGb9FefChbUahg3bB3mLQuNT7FFWT3PVY_U4HnGRa9hwWF-2Yc0peBqk8LL11EX4uXO3OZLfQ
Kind regards, Jack.Aubrey.
Tuesday March 6th 2012 . .
A preview of how the guns will appear on the trucks; the wheels are not yet painted.
y4mapUEpJCmJY4VBFwriU1DQPPgE4bpYlJBqCLPhDOdd49CDhGba7COg79sBdQIlNEB8VMImLSkxMUht6NPh58tj6lN_7v5E8hUEd5qb6okESC4HAVejuKe51Y_ApxQczsAanT9YuVfUcYsp-BZR2w_R3-Ce53S6PMKbbvlytybojB-X_SVaEVbg09Yr-AmdUDYiSBVI1HPSuXef_lDaqpc7A
y4mqmUG6cTZais2TWeHHgaUVCgglAY6yiZ3ueZjQQ_7spQDQjBOXuo6F5JjMEoy0wly1QWkGS6KqQLvnGzD1arczFhQsUPr0pMnlUcTzQ1kQnzjfIKGcYnqjZfMkJZLFMP5SIT-Bgapy2Rsx9b7-ObxTx0-rjCwZ9ODL46eThEvWJWIMox1hWON4cyzQQ9mCniDolKUmKlnE4Zhesyr8G2ucA
Friday March 8th, 2012 . .
A quick update of the work done in these last days. First three images show the boats support structure, the pin-rails and the "pazienze" (I hope now that you can see them you can also name them corretly) after they are painted with red colour. They needed a total of three coats of paint to achieve a good result, So, just to paint then I took three days . .
y4mkqgCejqnt5JNhYAMt7gxxy4kG9cwZSm51VpCxn5inF0o5Q4jXQDmYAh_nU7Nx_xrEBg1YPGLKYFSJk7-vfb0LRcLJYf_THECf08zKHT18EKa1zj7pRVU5K6tN9ZeNB3jE40ycwmXeY0rIrFXrtk948lmUYugS1iHCAWvATHe5GYuDjMwgYRTXIa_mPYQVzoJYwRiUAefcKlpDoybticN4g
y4mERUMzO32yXqt1g8fYAS1MZukjOa4uexZ3WZCGCUm95GO08KxUKEmzmjxQkJthzV6pEMPcfH-PEJpmPQxsBW-dsnlqE2rcz0RnuhPGpM6zfQeG3miQ5C-RURyaGmxCqOkLWwecUq1oqv8HsVx3Q62aL74lUjfHFfDbFBEW-tssMSSIxbd54AOx7nN4r4atMUby2Zg2zj6SZZtNMGPbVGtZA
y4moaosB-zQwih5YsscXRZ4Z9cDn7ZwnycugQKUjlnd8VsvAWUdGfeTEeEDIFHw3DLttxqoURXFjCFvKQrSkl3eWdSVy3vK_o3Wk2k4cuf54s04kpETdMAMIXbolumNhPzloevDOCJvS4n_-fHmWyqa2wQO_OYxBWWjjJFLxjxHMNf5lRfE0pLcosg3dPSlJl6CazFc76y4aRMTjob5-gOaFg
The pivots that come out from the bottom of these elements are the protruding part of brass nails fixed into the wood. They will be inserted in holes on the decks to increase the strength of the glue.
What do you think about the two decker shown on the cover of the book used as background ? It is a very interesting book about the plans, contruction and history of a 3rd rate vessel of 1678 named Lenox. It contains plans that would allow to build a 1:72 model . . The problem for me is that I have a lot of shipyards open and I cannot open another one !!
y4mHoP0kcfoQFLzMi_MXTV-iVUOvxJnU7Qg1MgD0qvTrUgco0sAq1etjJ4p5wzyvMb6yeEKEA-shxvjTjlvWy1g4xprK5j7_6MjQvsoTgnN484vjQAO8wKbZB4jMNbQCld3alB5H14TbVPzriT3zgSlWwvfcUZ6G1w2KwpuIwIcy6E3DTfoHhvhMGXJ8K2aqzFdJOlVellohWOlpkJ6U6SO4Q
March 16th, 2012 . .
Last week I had too many things and they were not involving ship modeling, so the productivity was affected. Result: production below my usual average, average that is often lower than the rest of the world because of my slowness . .
Here I post some images of the work done, just to show something, anyway uncomplete. In the first two images the guns for the forecastle and the quarterdeck, different from the guns of the upper deck, with their red painted trucks. Again the wheel are not painted.
y4mjthnaGeyCQLFCOheHtJwV_o0dQOubN8eVgGL1--W2e-lQ9EQtqHpQDfL4i85OYpVtk8jr3mw8N6uJAyWuIrlX7s6ZIrmlbGnV6xRbXanFu_0L1DK-jWIHsar8tnphc95dkker7ahOa5ThTMYJXuO93Z_YZaBYAVuD9bDt4TqRDF8rOby1P0vJYvdIBmOMuoy6BIFi0V0oPDUbVEKpJb_eg
y4mOk0CyTWcB2PhtTXDzAbng1LDn0m5JZz1ZQe2DycI5BjdMr1ppIftg-sGaVBq5fLruw50cYOi9tw8zhX0ILPS1kvOqQQ9aIGnK56iSWsPoT8z5ydnQu11fD9gtgM3kbNjDfCZXSo5CK-T-FxogekwLelFSW2vet00a51Q0Kj9GVwxz4yNQO1aPajYV4HpJ0iI-mReWu5XB_17q27QNdB2Gw
Then I started to build the four anchors. I'm still far from the end and here I show one anchor with the raw wooden stock and the other with the same element shaped and stained. Today I made all of them, including the iron hoops. For these last details I used a personal method instead of the one suggested by the instructions. I will explain better in the next message which will include finished anchors images.
y4mFllgbTr5qmjqvfwEZ_oCXakFcfvXjhDcb6XMbdFEVO34IL7mCg9ZX-qxEXg4yUEb22GwKC-Bi77cjRmzgwhnwI86XpSFMjdkaGsOUXJPM8ZY0GAU03h6GmRGdI_MRYzoZgUDL9YGGmpzvYe3DEjSEY992sG9e1A73vnjviXh9A2XFftU45X6DnrW3IJq15vMjAKhPk8X-Tr7OqrLWsQ8fw
Wednesday March 21st, 2012 - last updates . .
Here follow some updates on the new superstructures of this week. Not too much but the wheels are still in movement . .
Two images of the anchors, 98% finished. To complete I have to cover the ring with a drawstring, in accordance with the books describing these details. To fix the stock to the shank I used a bi-component epoxy glue, which assures a much stronger adherence that the cyan-acrilate.
y4m_8jgXuFo-xciIXBVABpcPWcwkJ73TVHYZANFH0Yv3yNz2uoMrRFHAh_B1SBnqnSjhlU36THoIxtUHolH-hcyeYQap9JOzly0VpXBlquMSu80p1cpOPmqU_kn4e5Sl7PiI77rpaEiwJ6J70esp8KG3BT5-ra2_uOyfWNprEzAfGMkxBphZsNoVAdCGdq2Y5AS_YFudeW7PVSBAm8dDy8Gtg
y4mH9qbQuskzMBmq9fAKK_f0JsWoNxKsYneMyTGEo4Oj2-jUwl3qEs1qzDi1EB3QDrwdKPLBp3li6bKuqB-BpizHcuBv0t3Gg_drTHoKXilxEMdoKYexIfbQ3XveXUja9rt_A9tIQ9C5fUglSh8A85ft75GOAHKPYF2wHvnPbxUTSA4zUyD2lEMNkpQl-0x7Gi6M5XPTmzuXtIjUdWKbtIz8g
Two images of some superstructures red coloured and the two catheads.
y4mGVAKgRs1p6BikqI0iX4XI9RyN9eyFg7PkbRbg77Sm-6qEDEXukTCWu72YIrntMAy0w-WjGhRhBuf0zbaENZmXNXh0Y0NB9zQ4KXf7b7GaL6E3fcfNvscDvcHhgyHmIyKCdBOkvLwg9oiYzMr2KXOXB9PI67MmjXqXjd15HOrwevV1v5jlTHYTeSIbEWst-PKjsEZEJErlDSOsY0OtqRyFw
y4mHgtbgSQMj-dmMI95Yw8CpT-yAsa01Hbx0_C5iUmkBCls9VOD28Z6Iwq6sefqBFSuRNm-HEGoF3B5R5Yo9o2yBunnHtoAM-YAtWpfglFq5JRep7_L0Oh0hyOdRTC7bOf-bUkrGF-_dZmbVn7pbqw09CPTx3cStavcYxkNP-UOErK9Y5yFNZ3CpSvosHJ_utnEG4Gar4ZS8Cuz0Cdki8Haqw
Friday March 23th, 2013 . . continuation . .
I continue today the message I started two days ago . . I began the building of the ship's boats.
I built a cuople of years ago two boats for another ship and I had the plan to reuse them, but I had to accept the fact that they were not of the proper size, one boat being too big and the other to small for this model. So I had to plan the building of two new boats: a not short and simple task !
I took into consideration a couple of methods, in fact there are several ways to build these boats, but at the end I took the decision to work around the material supplied by De Agostini.
But this doesn't mean I will build these boats as described in the instructions, there are too many details made in a way that I cannot accept; some of them totally out of scale. But I can use the material provided for the initial structure of the boat, that is planned and made quite well.
Anyway, before starting to use this material I made with a scanner a copy of the pre-cut keel and bulkheads to have, in case of failure of my project, the possibility to rebuild these pieces and restart . . a kind of backup . .
I know this task can be quite long, and honestly I started it with the objective to mix this new activity with the others around the guns and the superstructures, this in order to differentiate the work and make it less boring. I'm also waiting for new materials from De Agostini, materials that arrived to me, by the mail service, in a very poor state that I requested a re-shipment to De Agostini.
y4mqZibkgh0nSL8YWQ05UxNkeNNY-a8L7ZvNj-9TMdwXdNBkzK2ERpvad11LJKAeOUH1IXb-Ej2p8L7DUrAUztFhhH-MnRt0if3lUZm9c8jWuXWLux1iqRQO4imd4JaJgTVpwtl-DWpOv3PnZ8X9hqPH_mVIAiPNBndYCf5DG6OYsfpoX_ufalFAxzE5TDmINLmb0qa_rT8WhAt1Rzvvi32qg
y4mvj1TDu1bKTxKmyFyXFeupfLnQXK_MrcWcB89kreUlNerlFOk7hUP5dUNsFt71uJSXQxkKxg__xv3-kreWbdbvx0mUwFXGqDWoBTnI3pc1wJWmasYuf-gZuZLhoPZd8Jtc3iMbBAbFcjGDoQzZZx06ZGuBigx9egv5qMQmqZHeq730plAsKKsOLwe9uIq-M1JBMfWe7AKFBC5tFze3JT5Vw
On the fronline of the superstructures I started and finished the construction of the two privy (I hope the term is correct). They will be installed at the prow in the future.
y4mbS-_ay8r47JLVkEMCAQPyAyXPTCN2634ASYdwpLTwyCKS6ldOcqU3d5XXgxQXr_mt6r9zWTJd98LDO1tIMkAJIfbnvTRU_pyaAF6KIN9vxg34CAYhxVYgRze_0_HeF5_F3PqUbDLPO8vsj4ZWuGbXwqp7Q_9BUdrTh_KDM_58vti007iOAAz-bHY6HEoRiVRt5KomAqN3nybCyVuw2fYtw
y4ml9pt_IJWKQ8OJM-MrDsxysLGWkLOdd8h-Dl3HALx0fK6Gkenqi91jRQpjFG3-Zkc3aEqZy75px1C02AuttNjckGy0cWNXNLkWtDtiI3Yiblw2xJWO3bpEbotG1FELjxrNEWN895sLrQQ1fn04YgKrNYxU8IfU3JhjmozXJYI2cXBDS6mkIddUBpgHqkPiaW0GUf5nG1PBfD5v2-4QlpQ3Q
Friday March 30th, 2012
The last week was a little unproductive . . The spring is coming and the fact I do not receive new materials from De Agostini has "iced" me, so, all what I made is to start planking the two boats, and nothing else of interest.
An interesting matter is that the two boats are exactly the same, one is only a little smaller. Infact the same defect I found on the larger is present also on the smaller and this probably means that the plans are the same, just a matter of a greater reduction of the scale.
Again, after having assembled the structure, I proceeded following my own way: instead of using the supplied planks (3x1mm), I used my veneer.
For the large boat I used planks of 2,5x0,5mm while for the smaller I used 2x0,5mm. My intention is to plank the hull three times and then remove the internal boat structure . .
As probably I wrote some message ago, the veneer I'm using has a very thin sheet of fabric on one side, so the first planking was applied capsized, with the fabric outside. I think the reason of this is obvious: the visible side will be the one oriented inside . .
Yesterday, in addition to the work done for the boats, I finished to prepare all the single elements for the installation of the guns . . at this point I can proceed with different options: continue with the ship boats or resume the ship guns . .
Cheers, Jack.
y4mEJinnHkMJuP_UuYzqyAcdR9fhajdctTDOwoU23FiU1pzOKQ9jguvzio5YNoruW6VZtQKFKAm-deSY1PT6UMhSW_F1APws52b7sb9FW9Q2SSXoGulHICzqbhu-roeVSA9uLcPM6ydXcHvy1ykOBrXdwRXY6Zagiqqzd2SvyvFPaBNYyNIDeiWE_wfJMckl0aLXG6eh7kdgaMew8sCjr6SUA
y4m4ow9dRxeMk7sqA6Flyxs9p8ZzddjFg-ld7h9WTyZVB3NwyiAAWFAxJbLynZ8sPTUNBoGCbLEBkDE-sD0k1H5SLlTkJqIM3ZuKybgkmfL0cLzoVolycjkoRdbw2vKnVzmMa-KtQFBnmlc3aOw_NeVyjN5qkTvO_n4LdiYt0guEqyzby9hoj33owqp7No0g4paTTd1ZpdBXjvBPpsXI84SfQ
Wednesday April 11th, 2012
Again , also in these last ten days I was not much productive, or better, I made some important activities, but not too much visible and I can't show only few things.
In detail I:
  • Smoothed definitely the hull, after the application of the second planking, with sandpaper of decreasing grain. With this task I obtained two goals: smoothing the hull and reveal everywhere the same color for a given wood. In fact the color of the wood, in particular for the chestnut, was greatly influenced by the daylight and in this way I made the wood color homogeneous on the whole hull.
  • Applied a coat of oil for wood on the whole hull, having in this way the possibility to admire the final colour of this ship after months of work . . and keep it stable.
  • Installed the pintles and gudgeons to the rudder; next step is to fix definitely the rudder to the stern.
  • Applied the second planking for the ship boats; I achieved a good result on the large boat, while I have to start the smaller.
Here a couple of photos of the long boat, still on the working basement. Cheers, Jack.Aubrey
y4mpYIgOthineaHbU28rPavRGdND6RE_AAs0OxljghwYbjnNlGY_n4M6e8SQuaXfhnHgtX-WudW8sg81cDP6YBcb0m9vEEWXhKg8aSqjTRgk--9ZLx5oe2_GeWknD76SEPPWd1aRT5pd_1FT8QQ4Lo7VJdOjAXA4mHAfmbkRvWiubPatR7Bs-WmZBWuxIgf5DFX0MkCcvJA4bqdMr5cKTTfeA
y4mx62rQwN3eezKT1dVgj_UlUSq-vIXlEHnMS6H9aXAPlmjQ6vSKgk7B02dBeNMr0drXW6D1pIRw50HQGzGF3tft_Hoo68JY9-vogsxgd12VWC4Hm9yjMuoAyOsNezNAx8GqdotYzF2DFZLijgneXmfwrQPTh3l1JY52RXPIC4sj54nDgA630Cu6cd-le-yFohSAbutOcypeSIVXttPOfTxZg
April 12th, 2012
The long boat is now ready for the third planking while the smaller is ready for the second planking
y4m1spVf1JvrfP6ZvuEO6LT9BcFo9UnAPm4ztknGxWb17UAu8n3e3r39Vt42CUXJy7_dWDFYm45_2i1rCFm52ZvUaVWOikIXz1_HcVKwWgM0-agF4F_mO1gNn14qqm78y10ir0JXxrtOCo6MSx54ouqvIwMxXYtAiJSH-z4QQzrGF2N3fd0x-UyNNNbwDVhafXKwRuzbx7f-DXA28hjevU_Hw
I made a little error with the second planking of the long boat that I will correct with the third planking. But this will not happen for the smaller . . power of experience . .
y4m8yFMcI5B6Vc2rfdokRC2-QUu8cI-p6u5mqC_N7vNHs5-iHCENM7yo7S3-VNJlZkitKwS3pjNzk6vqsta_TOEFeBWqQ02w-qD0EuaprQqCArTJr_axqdOOokXm0ALdVHqmsWkci7jbdjMBlvbU2NeauHPQkLinfd1Sb7Z-jBkQvEVD8ENmQX8uj-AemW-VTJbqV2WPugOErRuBb0TGmNwjw
In the next image I show the pintles and gudgeons applied to the rudder.
y4mY_Qatsq-oQDLq6_wjSu-YAxw7tWkKd5adZayAOr0h5wzFulBJPpgVwQ782PGymL7ESU-4mv2gXPaiMQuoud64KnNV2l_5G6dwqtUqus20NYLJZCFcmOLQmGLIHVUkIVUUFlfXzLmC9D6aUgp7FBbzVKAPlvkLCamxkkG1KrAVA3UKiYw4zp6A-uVEDocQBedi4mNmk5i8UpEdcj1K63Mew
I have also taken some photos to the overall hull, where I applied some coats of oil. May be in the images it is difficult to understand the difference, but in the real world the difference is great . . specially over the mahogany.
Image 04 shows the hull after the oil, while the 05 shows how it was just after sanding and before applying the oil.
y4m0SkOyb5sEXTTSgFSvvylcg88-KqkwN7bQ09siw5MfGFZOvvo4nqNuvjR0CIyEcJdCIFeg51OlM_4WefvrNyrGcCt-nEiewiq_JEpJcypCnFly7vLqQc9SCsUu_Om9AcRIngxS_AMRPqhw3Gp-Wl750mnZNrpc_qYNNdN-w1wWbz0HeDDGjvFYATrpi8b_lcGGcEu31a8fTsRsw9Xs5ObFw
y4m8qijNpaxsEfDLqHHFhVuIabbFFmZ-fiFX-Bz9yhLIt_NJJJ7TtuXreJw64b0_fSvfRsjIhIa9pEEUwCJKQoFDs_tsfRrL-WzDOrNrh6D1JWv80yIThqukN-SaXj0O5aMtIGzjFXTEvXf9cjLNjHzxOSL3qYBAJ4pZo05UoPiIYD5_ayMN6DehDBwTdCu1LMsaNyXeoB6DhY7tVG2CEd1Hg
Kind regards. Jack.
April 13th, 2012
I take this opportunity to show some new images of the hull, after the treatment with oil for wood. Note that a kind of disappointment comes from the fact that the colour of the beechwood (Wales) and the chestnut (2nd planking), after the coats of oil, is very similar, and this was not what I expected !! I'm seriously thinking to paint the wales in black (or another dark colour) . . also if I foresee some difficult problems with this unplanned painting.
y4m9oiJCTva9S7LpOdZ0ME5kO0iSM7xMeyTbK-MCetAb4jCWaPOgg4v_s0yRyHfFDnp8mvfBAHGg6figo28fUHTqxqEa-qzM8XsfQWO38LIfe0-f9kasyr-lftfyiG8g_Kmt2NabPNEn_qcl1HY5J7_kh87Y46IBqTulcu-Cqc0ArgLgp6w-YmXTD-I0C-SD08_2tRVRokYSnIOBeJOni3FQg
y4mSyQNNL_58dFyFx4muyutWGw6GUpfZxvi5o3rOURmA7HP8aul_A9bKlB5ADCpyLMgUToLB3bOktyvQ2COFm7fQ4L4-iJnWqUM1XmCmqe4tPLfHgw0kaFlNrdLmamevL5AbR_fHgXhfA3P10GBc7Sce9sHRXfdOzH6kv8swDgnq5CeP3ZAz2cU4Jw0ncC99cKqRV9Q6yejCzHCnGM_yXdQ_g
y4mrdUNFHc0Oxwx0HsbjyzcCZLIEcwLKDrqvkH1OpTFpdZ1pP9uEVDetPxloWVKI5acE-WxQHbzchyDpKcN2FiZcZQDi_vCBG_-I8xRRRyRaYEzX6yPXQv7PcoCNjGF7gruBo93Bsi9ABDAPnQGLAAeKJ2LM4XxMsezYQj3KumfkSzdw4hQQfw7Z-9DRKPr-azqUxWskx5DIeB1fc5CysVYgg
y4mxU3-jOClBKXdveoHGgf3s4lRL-KHYuwTYz2gBjHsfEHdgMeVADeW8n5e2tTQyvJ0HxMkbWvf21h04OJ7733uNapEcYpKIfyyvl9GEK4JtoJteUYfSWgNmA21H1WksyHtdt_ABhyFaDumzUfT4suzHWglPA5WcI7KP3NszZR9KmszlhGjQfiAXfKOTbQSe69B53OtJuIV8SNZdHrVla6aJA
y4mjYJcOhhow9rckZiQQ4APerxwoIm1CZCGwU8Ya0SQxdcYAXuu0rme3dzpUPD9blRRAli9h0Rer0z8WBTdlhpJJs9-O47dbOkS2vPY3nHPt7VKWI4YVgdBOiXKPJl2FG8tN5qVg8aHvvlTZQktpxXsokGLZBuKrlptTgfednnpvWb6HvSMPdrLygkfQ34oVwd4SoLDTDOFaAGGCvcpv_WnxQ
Thursday April 19th, 2012
During these days I have mounted the rudder to the sternpost. It may seem a simple task but it is not exactly true. To finish this work I spent a complete afternoon . .
Another work done was the planking of the ship boats. Each boat has now three layers of planks. I have also fixed the boat's keel. The next step is to detach the boats from their building base to allow working inside the hull.
Friday April 20th, 2012
I selected first the long boat to work on the internal side of the hull. First of all I refined the external planking with sandpaper and then I detached the boat from the building basement.
Here below two images of the external sides with the planking completed.
y4m6_hB_IkIauvdN58LYzWrD0bJCRTfl3_R2x2HR4Nq_t1SEQdDn-4tDfdCIkc33G6NA5jHEPbrAuCk6zN_fboYhDpgBkFjPfGoD3ZqybIJpErISvmDSTgmxlVcCLdawUSR8FMhscPAQmAkByAIrC69pN9AXAZu2seou0cxWZanxpXHmjscem0auwZSLFK1eq8AYq34_fs1nP-MnoqWnjAimg
y4m4xCzAhfJ4Ct1ETlzzrhQ48aeEZdjlfo0fjR5ULSu5Xf3NPsw9oDZHV7hgwNKutmb8NOcRxzef-hXD0vjqFuaYhvsO1lmNlSu0fBWb4m99RxvUWAfjVelo_y-NkW2e4idTzwBiYkxY1pOmbaReaCuJMUMbYEfq_uMzgFcMxTgzG9lvOS2umye_S30y6KFYH2pT6NH8yoPMP9FMbQU9JpZLQ
Here, on the other hand, you can see the internal side of the boat. Now I have to start the task to empty the inside to obtain a clear shell made up by the three layers of veneer.
y4m-w7ywbfRRwx2whFIZ7IO6TG-2PSSy7fEnpl2wdQAkAMzdclH6DM6J0XJossTJ5n00_zw9FlM9zj1z4z5b4_7lMThglKvi5Litey_us85jt03oS7up843WjYMw4E2BIpU0wu3pgbHHCuF1tJSYvoNNdtnPq_611_JpI5VOAaA17A1ko4LRpxAlLDC_d-iJjlpaYyoWbekQW72Dj2XN9VLaA
y4mS5mxkpPYBjrlFXgk5TidXGwgciIDo1hFRrCtBQ8o_6hJ7f5jv-oosGnj21GyiM7uXa-Idg6BdCkJBl7O4lSzN2ZE-w2VzCoThnjXbLcZFtgiZsM7bOrcW9v77dTI6QLK9bUZCjfjq2fK-K8lGbDSxtJeT5oCvgIs2SELwd5j4igiwtiCWdc7vojSTF0ZA56GgPs9UrJmknjn49Segbx8fA
Saturday April 21st, 2012
I spent these days emptying the inside of the boat, more in detail only the visible area, not the complete shell. This tasks may seem complex but in the reality it was quite simple, thanks also to the soft wood used for the boat skeleton.
To remove the wood I used the Proxxon minidrill with the tool shown here below :
y4m0JwtY_0uHeQAnKV8beTPY-2hheXIBEF2JSCLAm3XUO12mkW0dCtWgDy3j84xFTqpft_vps_EZ6YG741_1qSLuTGW5-pN9_JqfBGnjdwyVyeMAJ08aBXgd70yXRfMPChQd8xoMbHNI6ARhiZ1G4yhkOPFuus-WKgfDy8RC4Ro4fdpRcNNfhGQVhHRKYJ4ktU1OQ0K7riP5dH7Cxbk0mMk-g
and the following for the final cleanup :
y4mT8OCSKBC9rxguIckinT9mY-vw1rt1caLVRum8gwUnrlWAFWH8bxT3T3XY6y4sZBycfKyWqMNlPsEjgquGB0iuxC9frC8O4IQ_wtEEwAMdYXRbl5Fu5rWalQMYCoaReVVfa1tJWzAexvi25fHX2rzOvyqpm1sCKvhINRdPHthDjSgFA69ddhf4izNtW8tKETKtaa1TpmSAi9TOCNrf5oEEg
Then I fixed the false frames, obtained from strips of mahogany veneer, and the bottom, from chestnut veneer. The result can be seen in the next images.
Cheers, Jack.Aubrey
y4mvFojVILDK89lfQqZxSQIPPwrIpj9WjOM70GO7NNmrv2g4DL2iYigRqk5r29vMl0Xzk7TYob_QZMyrdQOM-WT5yWw0SAXeCwPQIc7Yw8nyT7V6lOkiuLw7BKr_Gwe2Y_p-s3R83XYL90csPzwTHtA2z3AZp1KXmtKHjTotN2ooXeaxqOA4P96OKF1yCo5gNoIWSGNRpSWBizpjwEigOlu7A
y4m_GW1MtqoZOgeP2a8jVYDmTsgJRl_LFoQL4rDu4xgFiMc04R2H6qTqZC5wtAdjHAw9rBmLV-5p0lx8acowYIQCBvFQVXc7QWlEjM_jjf_cLNkIHpbWGGuPPa8DYQAXxydCLQPTqe9grxPbxyvEj53uQBtlPoX424SCdazkxfdcPvTZC0aoxcamloJI7plR_eofqu72HeFNqiDWgtInbfnPA
y4mRoYSuRUYweyPyZkj74JCdU4ft9l66q9cejvH9PS03dV0LfgjgDeBJSsUu2WmAa9AjX-qbH7-vn_fYCHKLXGoucwEnzr2vPsoLHL0z1fgEHnIPM3yPzn_oBbcUn2hek1Zd5lqPJqdtf9-Ed7xk9uZkQvfaYnJOZKQDrf27k_Yle-ArjU8Ud_REdXJtsBjjSEOrIe7eFil3Pnz70C5i9D2Ig
Thursday April 26th, 2012
I continue to post images of the work done for the ship boats . . here I introduce you the large boat with more details applied that some time ago. I don't think it is worth to comment the images.
There are still many details to finish. such as the rudder, oars, etc. and after some painting in selected areas. Then some reels of rope, a couple of buckets or casks and the boat should be considered complete.
y4mNxpM_TDlrTUNZ86eAqCHktAuf7ddXXG3eYpSDUvDg1CNPSzIIPGZ5RpTREqrPz0AV_bH77BEK6Ts8hF278SVILrlcagVtL-PBJoHEksnSwHmKGHZ5qS4pu-mN2xLl4mSrg58WYrn7ELPACp8sHgnypV-FX5GTRGe4uuCIJSJTHPbkl8ZX9tNHGE2LhDSY-A3RL1h9yD-UKxqI2WITd-jXw
y4mbjmfvkDbyIUNwopQncVz56einux_HTo52etA0EYLhfi3zYskaapXg5zbTQRldNlhD0LQnzT5tmOTrdwgh4CoegjaENBHJUjMAB_rxpPw1Y0SH2YKouAw40a-1gIbTRvHiUOIGanXEv6nFVuMyelC8KrpmxNQmiYDRcZlmUb4Z0jlj-3QBrocwIADtOpfn7krlQRJBfLJfqmgY7E8mA1zTg
y4mJeR4GCb_SmQ4gdETo5V4ygdOb6_vM5uViY8QHGuBpr-YoSG_WS60WlkKor2YcnDMLqm7jFwV1IVNEmJGyd2WCSmQk1Kl9LPY587QvSA-4jk9yrejoe7-zj74fhbUhWCZdFIpgkt95mG_U3ddA3G5AiuSdC6c1zFdjujAtUOKR_acihCiErDFAERudUDBeJz-iAft0jbBaqu9j43ukdfItw
y4mKQSPD4D17E8N_TXqwoLdozx6PUlMEoD3I4EbZBFzhKF_2y7h6Fig9JpxoB6phInFM75cqZ73COWZ-_9LWbUEKQ5ZsLzenWbfwS7Ge9Psnx07dv9k2CRA_P6VrpQ7WJrHxquxNkjtmFasrd6aIQzshQLeh3kWvqvTZVOtWxyJJsPoXLxQy17eeCsEROzJmUIFscCHhZbs0IKIC-Q0_3R7ag
Monday April 30th, 2012
Hare some really "visible" news about one of the ship boat . . these news required some time to be achieved mainly due to the long time intervals waiting for the paint to dry. I added the rudder, the tiller and also some false pintles and gudgeons.
I have then mounted the oarlocks and now I'm trying to build the oars . . I'm using for them some components taken directly from the kitchen . . Cheers, Jack.
y4mkk2XJbw3lvVkFZHWLhOW01Gn9hve234OW9Ze3VRR0akhCh53vgktK6RA_yf8PTYIdrnyxbhWziX6glHAItx9YC-QR5coqS-sYFoVF94Au18PixERfv9FJKKIr1_kEHINwQZXGghwdGx23JzQh_KBCRWcv9x9c_mJj5LUCAIQaoGZQnwMtaKWL6gLpOiLC1Amt-QzNMCVyG0S-BOMoax-JQ
y4mGmwWkxzhhMdNuZdIhA5JlYaxorGWFvdQM884gSsTgw3NRT57bWOAVsSsZvhuab5ts0LqxzcaNfHdXNJWhVycS-QDDsGwJ3cLJdGwjnUr-lquYKsOEyiVWtuO_cAfXvjFJ4QSeaX88JQCMh0cvyZO5kKmyIH9M6ZaK34iaIG-tJk37lDy5XVtHiBBzexHFUveCZTZB2Iq-qOpQtJfc2ViIw
y4mOf4woN0FJEC7sv8FA_jdWVA7nmXsQJynbLEc7xYoj9frNzd13uO8FkDqQ6_vq89-DkRC4yuvtoYt231XauKkGD3ZTj8oWLUUKdZQ4E1UWlFaHCoCnv3ieKlUWeFpms6-9QTCiR1wsz8HJjewUpX7kcLK6jrUmJ1JUxvBs-vgNhU9pcvScODW8TO0JvMLP99DqrjyE_ixEh5yC3Ko1411-w
Thuesday May 3rd, 2012
Here are the new elements I prepared in these last days: the oars for the first boat and a kind of boarding ladder that is positioned in number of two in the front side of the forecastle. Regarding this last element the instructions where for me unsatisfactory so I decided to use a different method.
Boarding ladders: here below are shown the instructions suppplied. As i said this method, given the small size of these elements, makes things very difficult to achieve the goal to have all of them equal and correcly positioned. I used an alternate way that I show here.
Full Size:
http://i46.servimg.com/u/f46/12/86/14/83/090-re10.jpg
First of all I made a special strip of wood made by the union of two different strips (4 x 1 and 2 x 2) glued together. Later I prepared a small table of veneer (mahogany), then I cut 10 steps (obtained previously) and I fixed them on the veneer all at the same distance. The day after, by using the table saw I cut a couple of ladders of the right width (8mm) and the boarding ladders were ready to be fixed in the proper place . . another way to use the table saw and another experience: I surely will use the same method when I will have to build the "true" boarding ladders on the two sides of the ship.
y4mqOqLXbOeMqMyHDE6Uzff-IhTu8ghWq6NaMmH0Lf5TYHxbqrmYKddHrRIwSOia2cF0MWQf9RY1K3kgao1XcfcYXD-jQdxt7gHx9xf3697jGAqnn6k_EYaFfyFNVs0l5NuWeQFOZCWXAn7OqEsVxhSnU4RJbBjM6hWNIaVvU9lvOuTM40M76NGStLkpiWnbEU21RCm3wG1gMryreEukg2t1A
Oars: the raw materials are toothpicks, some strips of beechywood (0,5mm depth) properly shaped and paper. The oars are painted with the same colours of its boat. The total number of these oars should be 10 but I didn't build all of them: I made only four . . too much work . .
y4mS2g9OcUcREPQ0EgzZ5OxO65PEsplAmSIV5jc69tz_XbYMR4xVr0Qdu77PySw_UuZXHHwg9sf9ki-SCXW9bINWyQJ6RarKkxdiBCKuyZNfD19KfSrQFZeqX80ZyoyWfAYhDu5zBTwqHf3Ns9LpNC9GJUt2H3fbApXLs6uV9b7K4TGQF_Lft6m-KE8yRFKnYWbXF6uhwKmw3v-K7TdPJcCRA
y4mfTfwxGYZWTpr0mKEOemWlZHee4jJ9r2f4GygRtHNqgEJsfxCDUJfXOwv0e0I8Vyg6LR4LndMCqPZWVqm8IThigjwyq4ye7uM0xO7lMpjYxNXFIvoJdAVd7FiH6oeeZacfwpV5LhaKTqxHtQBPbNdprGsvrfFX9k6cN3gx2U_jZoYLqRtuuH36oS5jo4aJvf7xiL9pZNjTknKimQUC1rWTg
Cheers, Jack.Aubrey.
Thursday May 10, 2012
Tired of chasing the construction of the boats, I took a couple of "sabbatical" days and I enjoyed it to mount some superstructures in the bow and stern area. I had already prepared them long time ago. . in short, a slight deviation from the usual routine of last recent times.
Attached are some pictures of the superstructures under discussion. Unfortunately, the red color is not very "photogenic", as I have explained a bit of posts back.
y4mSpLvOH0tUM6k9weEh08URTpqzoxDWyN8ysvltZYQIq3W46AS6cm3CUCcVbmps8tLFx-35wPo5NsJHClQ1toTM_dQRqBMBhi86chb7i-vT33wPLznLoukV9M-Bio8flW8U_QONKValBP5W3zWfW0MKcP-B1FWmZmQgmgbFk-fB527OMJGjVE4YryYMoqoKXRwIHl2pnqw-BjYQs7Ava3xig
y4medUaXhp92W70H_o7WNIf248bh5NcRr-euc-GTtW67maDFwJgMpnlqfSXI6j9zpUBVghWk-XDK4mLtAz81UqXL8Wm6yRqL0d1OnCKk5Hoyr_j8ndUSNQMy3NEI_jhpXNM5W1y54xP_jl08IZRbhe7POCOv18xaxqvVE2QkMnOG3iX5RzDg_Vz2POb5JJOU4Ju4WUDgJv5Bp76uQXIvzqXSA
y4mBnlMm4r_WpwCoKOZdMCY4QaQseCdvLeL_QMKpcU9eh0xKhNcpjjS55uKyyP_iTaunhMGwr59SNJQTVFlfQB1E1iJI0fg4O3y9spKmrRSH_MErF-znn5iF65_MpoWJt8g0HKElIAA6AuiGvtS_fv9cTAr38sAQ9ojVsUZGDkcPQ1WgNZX4F0CjonsG9gLoAxfVLZKma36msEiCjvB7TdS7w
y4mJMcMzQ0LhuSxk4TjMRtIs0_e9JlR2_3j9BxwJ_6GXz7sNzQpPW75Xy-fdw3kibSmI41vY21TPHSKRdPkGCZKsDJAHvJ4cyv5zFIFRsUWSY8akUtYwnRNrUw_e4YjttRtjWJZVDql2T3HQ6sMNEm-c1ZjRdGCzAMN9GXWKMw8V4MRdnWCxmme265i_1Bgr5HBKUO-BDF692NS6FLo1L8VOA
y4mq4GBQNeKHFhULyJy3m4xLY0o8OMB7SGDFN0hk92wur9h3Q4kNnIQajL0MTg6Ha4VKb3OUsFDMggI8ndENbs2ZjLqidDHHCpKbh8aqYNlBkUHk_wJDBMDTlui8x5SiT-kx98REaXyDkUst7QDllqXC1KtLG0_42g2Mo3BrpVnD0thnblVEuHpcJQQ3a78S4mce1LsLjh5ryKBemcwnW7gCg
Kind regards, Jack.
Wednesday, May 16, 2012
Two photographs to show the "big" boat practically finished. Probably when I'll have finished the little, too, I'll build a couple of buckets that I will place on the bottom.
y4m1HPHwMN6zTxJRW94_QSiNJOoIGS8ptxwN8Wz4GbfhwPAUuszBpQv6nocr2820E5sxL2mNp4H4wR3g5-gTJZX46n4m4s09bJ89iVO9NuKJQllSGga1-8PI6SNfGEOYNmfmQqOZTFYw3INjBXaW6rogSSp4XbjEW6DDqdQf7LTGGsLqSsN-fQAuDe7nO5qVCOgA6X1AaIbhSlZ3Uz52oIdPg
y4mdA4xLwcO8br4JItJVHqleZVxksNtgD4z4bYNHcm55kY9aWgSGYGX5iokQpkQDP36szZfTDb0UUza5v5iryc6xMQ8EEP6k9JZR1CoERuxoAx3YIX60thCe4hO8qEMhaM_7hvIyjhxmImyHPS4H1oXeWl9tW3JVWvb9ru9IevpLb9mv-qcKXkAJihQGEVIdOWixQH3HLoI-XVqp4DWpEnHLg
I promised not to publish images of the "small" boat, until it was over, as in fact it would be a duplication of the construction process almost like the "great" boat, but I remembered that I missed an important step regarding the emptying process of the internal side of the hull, when the same was being detached from the building slip.
So I go further now to fill the gap showing the "small" with the third planking terminated with the interior emptied and ready for next steps.
y4mGyfOzYbO4KzLezWlpAk-yv_tHMKZoaoKSDBoxtmOV15W43GVdsjAQSRahOfpeDspiHg8NuyoNNprHVpwQpz8Rn37LnS95yhzWgNmiMLj10NQkxVWCGZdec9afAD2jxsuAitYTZN7t6zzb5sIJfPeRaAeeDOtoOr_HlbcM4Ko68M_7yDGGc762lngrKeFrPFtIgoHcjKKZnQF5twWbJCxwA
y4mOwLoNUpTIq3k6LFZStLz9W65vqnDZb7bXEy_dlOz_zxP1wZmdXuL5fxtR-o8OdN6hFfjcZPjrKkAv_L6-y90glrGjkWdhl-94rKK4wTT-ScIf7CEwfoWhcJv1HKh28peCvQu7B5wjdFvqqsKCtGKygG6NI5AfT5NnO_-YUDHbTrX8iPd0_63F_4OdvMBn3Ml_4L9egPpLE0UmfZL2GZJzQ
Sunday, May 20, 2012
This is the "small" ship boat, largely completed. It is not really 100% finished because some small details (rudder, oars, coils of rope and dry) are missing, but the more, that is the hull as a whole, is finished. I must admit this boat came better than the "big" one and I think the best method would be to build a prototype, to make the necessary experience and then, enforced with this knowledge, build the final models. Obviously the time of their completion lengthens but the result improves.
y4mfc3FINkw4NudTknyZyzHalgD7AkjVq3D3VIToyMhXNWD1dQvpdnUyWKnyGiXjcVu7GoWsicoGqufEsynaxseD2dY009hW79c_qhcOIjVdRTynaleV-SykvoM3b3c6ecBMt-Ei8nZxHabj43OdFExz25O2mW2fSDRHV4FUaggqE3NM8272l5gbLL_4T3Te6Wrd1E610_tJpES7_P182IsNQ
y4mgeFtOzITM48whmf4dNmgyktwOUsl3hEAQvYAylAuvquWS5VbCck-f1Ix9vyIQdopPjDcvBbmMJgiah4QFjpvZsIvV96mFaYiexp22G3xVUDKk-bTc3SnR-2gaV7i3WtLfL7FbVJ2K1j2jAr45HBSlqNsGn_QnreOXH3hpvkXql16sr1W8aIc6yIxvSxAKysG311aRKdxOdtKpLgKQct-vw
y4mIle__JgMgCHOqb0LJhbQlIhTUEz60-ZgueUC_5dsW5a9DCOPywyuxdhY8FF4HCZRdj0FhB5RWevMFRQtzBdsxBf6CLNyPzvvc4tBGZZVP-cb0qAvmQMafvM4ky9Lx3M7X2dHgPGzV2dgMNAX4kq3D0m6wwoRpJrT9zx6WKb5rgEByd6UQFivAZaUNIXzOdwjhs2CsxNBtxpWhbqR9Nhaqw
y4mrEE9Dwjvz48JKPLPd61iDOM5LUzvmzRkXCNct0vHyeHxJtaf78tpeM9UcgIWSDgdux2EHO4bNCueOJGIz783pC2RtukaBOSLZztOxobXySh5vjHGbOA7W7Aa7kjPkfJSnjh19p2tJDj-QQ0J2A7PSuivbY-CoTEX4p4iYpyRPeOiDjOTh7azARHeiR7vYPfj_LrYLpzZax6NehxNT_6AdA
Kind regards, Jack.
Thursday, May 24, 2012 - Starting the installation of the guns
Now the time has come that I can no longer postpone the installation of the twelve guns on the upper gun deck. For this occasion, because there are no jobs that make dust or mess, I temporarily transferred the site at my house so that I can use all the useful moments to complete this activity that I remember often being long and tedious.
This morning I started with the positioning of the various pieces that will be placed on the upper deck: I drilled holes for fixing "pazienze" and "cavigliere" around the mainmast, I similarly prepared the holes for the joints for the structure to support the ship boats, and finally the holes to "nail down" the carriages of the guns, when it's time to fix them permanently.
And now this deck, as of now empty, is "magically" filling up. .
y4mmc-mZ7IQmaoD9yT8DTqmdn0hxU5h8fBEl1AVgiB93X__tfTFLq7duJLpNj2iM5vJa5XNFfKDmIjgUY_UenNwb85imewv3OtS6pWZXGBLATL1LiGyIsCjzEBNTuQWiGTuwprieMLszTOof1HVyNiSNuvxvM_MJ4gT9Bu6mJO1LW8NkGdpLYaO2HiUUSh0h69Pj7yR7etGt1rTB0Gmf4Nq4w
y4mhrR-fUINr-Y58oK4S85cubP8hEgPc7DsPucqjj0xh1sdc1eyDnYmvboFPz1P3ZXgck7_Sfs_-9rpHXQz3BOM9ljxHDiM0b8speLLiaiKeLIXBy9u1D91D_8BsF_SEGcDX8m8Wj9sNiIQUtPlUPr0hURG2EM6LUG2FXgtOvzBnewh9iW7wtdN4x3jRkA76Z2g7gSg_R8QqyPxRa3is-5NYw
From a very early consideration there are three aspects to keep in mind:
1) in the images are visible five guns per side, the sixth is almost hidden under the half-deck above. This trolley and its cannon can not be fixed by a metal pin as it is not possible to bore the necessary hole. In addition, the fitting of the same is virtually impossible, unless contortions and acrobatics think out of my reach (and patience). If we consider that when you apply the gangways these two guns will be almost invisible, I think I will just paste them on the deck using the glue which I think is the most suitable for this type of bonding: two-component epoxy glue. It take long time to dry, but on the other hand are as strong as, and perhaps more of Attack and less sensitive to sharp blows that cause the release of Attack.
2) Similarly, the pair of cannons on the right are partially covered by the forecastle, but here the work is easier: first can be fixed with the pin and also the fitting is possible, at least for the exposed side.
3) The structure for the housing of ship boats, positioned as instructed by De Agostini, is a place that hinders the operations of the second pair of cannons on the right. And so I'm gaining seriously consider the idea of moving it to about 10/12 mm to the left. The problem is that I have no idea from the instructions in my possession, if the area would go to be occupied partially, that is marked in the black box below, you will have to accommodate other superstructures. The plans Sergal would seem an area free, apart from the ladders to access the decks. .
y4mfGZXwEMOfr3sM9I77unwip0y7PLn_3-ySdT26JjeFRsaTWEMoHw-aC-LMKMfY4IcoyFXyJl0vns6jy1jQ3mTkZtMInnBR1Rt1ObMCcIrJ3HTpQM1AB7z-YihFKQbh6L87kD0E6TtHyuPSY69Gi8BymIzTUysHGL5oXcWtDmmxwf2H80oxrnBXZ2JkTSSvmrqe6i6xafyzjyuef-tmZbOgA
Cheers, Jack.Aubrey
Saturday, May 26, 2012
Today I returned to work with the guns. I'm at a stage of the assembly of the guns that I define "intermediate", there is still a lot of work to do but the more critical activities and requiring precision can be considered concluded.
In practice, all trucks have been fixed to the deck below by means of a brass pin that runs through the base of the truck and slips into a hole in the deck. The whole thing is secured with four drops of Attack Gel under each wheel and also the pin is glued to both the truck and the deck. . the pin head can be seen in the images in high resolution.
y4mpFGEyTgENsvUiYD9oz0NM0niKdhAb3MJbki8Ey6pdFPuGNVXmgRJxXh6neUXfQ6GfyOWRKuM6JQyJtNi6BPcPydGv_G6Gou-1XcmH_GmHlBaj-0iUWy2WYXMnhXoMWKPWKJs0bA-KzU9tFQumvVQK1YL8IMatX1pyglrM1PKL-_EewjBbY7agqwacONtB5TIrF98XUWUDvf1NgTGUHSoyA
y4m_m7LBR8BZ7WCBo7iMpCLrO7ZWLun9W-J9YUC6x4Nir9wxhcacD-CQk4bdo0x4QzG-jIrOMBM_4i6D74RIn2PTcyfq33UlMByr4OjdCSOtnyGzIkVKr-6wORXo6vvuRmUp53I_H16g-OnZ5dqwjt_uLzQuNyLKzEDlSLxp3rAKPwYYQ0_kO6gSJW7ElYUJJszZ7mGfkrIPAVWJ7jg1ob8bQ
y4m7G4bOJcVYciw-3WZiHD81uS7DWE8rJJuhJxmgi_iGWPJW8y5Uq8j3fT8MmNadAfobbZuPuzqjRqKKKqDd1uboGx4KPuuQz6JHmgrY0mgEoyiGwDRzT7ma5VXhvTjCzp9xpG5MgWmKWlG54LymBxagIeg8PtAnZrXylSREFeD6LpAo81laRDmrJI_x4BwArFyRazc_lDIQ-6BdXVmKRP_TA
Sincerely, Jack.Aubrey.
