- Oct 15, 2017
Dave,here is the idea in images
start with a bodyplan
use those body lines and cut out sections
you do not need the shape of all the frames that go between the body lines just fill in between them and shape the hull.
when you separate the the sections you have all the frame shapes
so all you need are the hull lines
to build a plank on frame hull
Thanks for taking the time to provide a clear and concise explanation of a very complicated concept and task. Yes, I can see that taking this task on would be VERY time consuming, especially if doing it for the first time.
My research, as to what other possible ways of performing, basically, the same thing, is to scan the body plan and half breadth plan into a CAD program, trace the plans to create the electronic version and then basically slice it up like a loaf of bread from there. Much like your suggested approach, but instead of a physical method, the electronic creation and manipulation of the same elements.
Ok, I'm going to ask a crazy question, as that is where I am, at this point. Do you know of member of SoS who offers the service to do just this; extract the individual frame plans from the body/half breadth plans. I'd be willing to pay a tidy sum, but not sure about how to approach it with the community.
Regardless of what happens and/or where this adventure takes me, THANK YOU! You've given me one more thing to think of.
Cheers,
Ken
