Marine steam engines and boilers
Hello,
Thanks for the update,
The information is 4 copper boilers were placed in pairs back-to-back with a common smoak stack.
It's a pity the diagrams are not a bit clearer to be able to read off any materials specified. It's clear that 3 fireboxes were in use per boiler, though not obvious (to me) what the horizontal tubes are doing.
It's just curiosity, as I said - in modelling terms you only need the casing - the external; visible bit. And I don't think that there was any period when boilers were not insulated with lagging, and a shell of some sort placed over that - which is the bit we see. Ships, railway engines, traction engines, and the good ole African Queen all had that arrangement.
Looks like a great project though - you'll be out of mischief for a couple of weeks at least...
Best
J
The drawing posted above is of a “Flue Boiler.” This is a very early type of fire tube boiler. The upper part of the large box contained the boiling water and the lower the furnaces. Below that was the ash pit. The hot gasses passed through a series of larger tubular or sometimes square flues before exiting up the stack. Above the box would be a chamber for collecting the steam and hopefully allowing any entrapped water droplets to drop back into the boiler.
Since the large flat surfaces of the box were pressurized by the boiling water
the boiler could only withstand very low pressures. A gage pressure of only 5psi was not uncommon. As I posted above, the early engines that these boilers fed generated most of their power from the vacuum provided by the condensing steam. These boilers were fed with salt water because the condensers worked by spraying seawater directly into the steam exiting the engine.
Copper has one useful property; it is an extremely good conductor of heat. It would have therefore been preferred for any surface required to transfer heat. Otherwise, wrought iron would have been the preferred choice due to its higher strength. Looking at the drawing, the box would not have been a heat transfer surface and some surfaces were in direct contact with the furnace where copper would not have had adequate strength at the high temperatures involved. I believe that the box would have been made from wrought iron.
The flues within the boiler were major heat transfer surfaces and coil dwell have been made from copper.
Roger
my idea at first was to build a diorama of the engine room. The problem i had was the fact i knew very little about steam engines. I did join steam engine forums but got no answers to my questions. Perhaps because no one knew much about early steam engines 1840s. I do have very detailed drawings for different parts of the engine but no drawing showing how the engine was actually built.
The one forum that really got into the engines is gone so after that i set the project aside.
i think an engine room diorama would make an interesting project and i have quilt a collection of 3d files for engine parts i am willing to share with anyone interested in picking up the project.
At one point someone wanted to build a working engine using compressed air. The problem with that was all the paers were modeled a seperate files and did not fit together so that ended that idea.
testing image size
the original drawings are difficult to read so here is a 300 resolution image that can be "save image as" and zoom way in.
On the topic of 3d-modeled, printable steam engines, I printed and assembled one of the Titanic's triple expansion engines from this modeler: https://cults3d.com/en/3d-model/gadget/titanic-s-engine I printed by FDM with PLA, so it is ok for running with pressurized air, and is very helpful for understanding the reversing gear actions...
I also recently chanced on an auction of someone's collection of boilers and steam engines, and hope to acquire a few (ends on Feb 24 2025). :) Let me know if anyone wants the auction link!
Please supply the auction link. Thanks!
Incredible model!,
For those interested, Titanic was triple screw; two triple expansion engines, each driving an outboard propeller. Each engine exhausted into the same low pressure steam turbine. That drove the center propeller.
Roger
Search for ‘steam’ or ‘boiler’ to find them, I have some low bids in but expect they’ll go up fast near the end.
has anyone ever tried using google patents to get the actual conrstruction diagrams for these thigns...
they do exist.. not exactly dimensioned, but reading the text, and getting the overall dimensions will get you there.
Bear in mind that a drawing for the patent is to show the idea, and may be there to mislead the competition. Especially so in the days when models were needed.
If only the models still survived!
Though I suppose that even if they had not been lost, when the patent lapsed, they would have been destroyed as having done their job.
J
Here in the USA the Smithsonian Institution does have a collection of patent models. Since issuing of patents was and still is a Federal responsibility, the models were submitted to the US patent office who eventually gave them to the Smithsonian. The logic should apply to other countries too. Jim is correct though. The patent documentation including the model was only necessary to demonstrate unique features that were patentable.
The American Great Lakes, where I live was one of the last hold outs for marine steam power. The last coal fired triple expansion steamships sailed into about 1990, and several steam turbine ships are still sailing. The SS Badger, a repurposed railroad car ferry propelled by a coal burning steam plant using a Skinner Uniflow reciprocating steam engine still hauls trucks, cars, and passengers across Lake Michigan during the lake’s ice free months. There are also a number of ships with intact steam plants preserved as museums.
Roger
Very interesting thread. I enjoy taking old drawings and tracing them with CAD. I have done some 3D modeling as well using Rhinoceros. For me it is relaxing work in itself and there is much less wood dust.
I have use of some nice equipment including 3D printers and computer controlled mills. My current focus is on using MasterCAM to make cut files from Rhinoceros models. They are then used to drive our 5axis router in order to shape model ships for experimental use.
