Mike's 17th Century Battle Station
Guys: When Mike was cutting out the decking and planking, he took care to move around the individual planks so that there was a true random pattern to all of them . That was a great idea and it’s paid off in how great the decking looks!
This was a very wise decision to mix - othervise it would be very unrealistic if the pattern of the grain is continuing within the neighbour-plank
Mike: confirm for me that the gun port sills are appreciably thinner than 3/16" and must be sanded down to fit the mortises in the hull framing. I measure those mortises as a hair under 5/32" (maybe 9/64").
Yup, that is correct. Build to the model, not the plans. I used my Byrnes disc sander to very, very carefully thin the sills down until the proper thickness was reached for a tight fit in the slots. I should have mentioned it. When building the prototype, the soft basswood sill parts easily pressed into the poplar frame mortises. With cherry on cherry it is a lot tighter!!
In Australia we haven't used imperial measurement since I was about 6 years old.
I'm so glad that metric is so much simpler, that talking about 3/16 or 5/32 etc.
It's hard to teach an old dog new tricks!​
Happymodeling
Greg
It does sound funny.. Doc and I seem to jump around from imperial to fractional imperial to metric depending on what we are doing. I don't even think about it anymore. LOL
Today we are back at planking the lower deck of the battle station.
Because the deck is curved, I very slightly sanded the bottom inside surface of each plank. This will help ensure a tight fit along the plank seams and help us end up with the correct number of planks.
I used metal fences to ensure the planks were installed square to the cherry beams.
I used dots (nails) of gel CA/super glue to attach each plank. Notice the fence on the right.. very important.
Where did you start the planking, Mike? At the bulwark or at the inboard end of the deck?
Once again... I forgot to mention... start at the inboard edge and work towards the bulwark. Once you get to the bulwark you will find a partial "half-plank". If the edge sanding, fitment, and my math are correct.. everything should fit perfect.. If not, adjustment will be easy. We shall find out soon.
Thanks for all the views and comments. We are having a lot of fun with this build. Have just completed the lower deck planking. Take a look!!
After lightly edge sanding and gluing down 21 strakes of planking there was just enough room left at the bulwarks to install the custom half-plank. I needed to manually sand it just a bit on my block sander and it fit right in.
Then I wrapped a piece of 320 sand paper around a wood block and lightly sanded the deck across the grain. This will even out the edges of the planks, slightly tone down the caulking effect, and provide a nice smooth surface for the finish. There is no need to sand very much as the parts are already precisely machined.
I cleaned the model off with compressed air and gave it another coat of satin wipe-on poly to include the deck, insides of the gunports and around the areas of the lower deck framing that are visible.
With the poly finish the randomized plank grain of the hard maple really shows up nicely.
