If I remember right Chuck hopes to open back up on the 17thSyren has been off line for maintenance for more than a week.
Thanks for the thumbs up! I've ordered Amati #1406/01 Viking Longboat, Drakkar. My wise is Scandinavian so thought I'd do something from her neck of the woods.Beautiful, gorgeous model!! Very detailed work! Great job.
You have mentioned the next model, do you know what you will build next?
Thank you, STGCS. Great choice of the kit! Well..., we hope you will start a build log?I've ordered Amati #1406/01 Viking Longboat, Drakkar. My wise is Scandinavian so thought I'd do something from her neck of the woods
AbsolutelyThank you, STGCS. Great choice of the kit! Well..., we hope you will start a build log?
Congrats on finishing a great looking model, and on all that you have learned. Rigging that Viking ship should be a nice breather after Rattlesnake. I recently finished this book on the Rattlesnake which I enjoyed immensely and would highly recommend should you have the interest:I've ordered Amati #1406/01 Viking Longboat, Drakkar.
Thanks for the tip. Just ordered a copy from Amazon.Congrats on finishing a great looking model, and on all that you have learned. Rigging that Viking ship should be a nice breather after Rattlesnake. I recently finished this book on the Rattlesnake which I enjoyed immensely and would highly recommend should you have the interest:
I have just started Rattlesnake and am being challenged. Have only done entry level models. Your log should help. How did you do the decorative metal on the stern? JKB…new memberI finally got around to doing my first build log. Already well into the basic hull so this log is not from the beginning. Started by building a clamping base to hold the hull from aluminum angle drilled and tapped to make thing easier to handle. A lot of time was spent building various jigs to keep things square and sized correctly. Need some more sanding then will start the hull planking above the wale.
Question: As to the paint - what is recommended, flat, matte, or gloss? Can't decide if Acrylic, enamel, or lacquer is the best way to go.
All criticism greatly accepted.View attachment 126958View attachment 126959View attachment 126960View attachment 126961View attachment 126962View attachment 126963View attachment 126964
If I remember correctly I started by painting it black. After drying overnight I did a light sanding on the high points then with a small brush touched them up with gold paint. Hope this helps. Welcome aboard JKBI have just started Rattlesnake and am being challenged. Have only done entry level models. Your log should help. How did you do the decorative metal on the stern? JKB…new member
Thanks Darvis - Checked out your Couronne. Very impressive.Wow! Gorgeous ship! I hope my Rattlesnake comes out that well. It won't be started for several years yet.
Perfect. I can do that. Thank you for your help STGCS So glad I was directed to this website.If I remember correctly I started by painting it black. After drying overnight I did a light sanding on the high points then with a small brush touched them up with gold paint. Hope this helps. Welcome aboard JKB
Are you glad you did the planking from deck up before planking the hull? JKB. Your pictures are of great helpI finally got around to doing my first build log. Already well into the basic hull so this log is not from the beginning. Started by building a clamping base to hold the hull from aluminum angle drilled and tapped to make thing easier to handle. A lot of time was spent building various jigs to keep things square and sized correctly. Need some more sanding then will start the hull planking above the wale.
