Yep that is the plan but I have some time till I'm there working on that part because I'm putting my detail work into the deck. I'm taking this nice and slow to make sure I do this ship due justice.when I used balsawood blocks between bulkheads it was so that the planking would sit more regularly without showing hard points where is crosses the bulkheads. (Mamoli Friesland)
At first I thought your car to be very small! Then it occurred to me that OcCre have revised the kit, as mine came in a box 24" long x 16" wide. I guess the false keel is now one-piece, not two. I hope the rigging instructions have also been updated, as these have been known to cause much head scratching. Mine took me 15 months to build.So I have been waiting for a couple months to be able to get this ship and finally got the chance to get her. She is quite a large kit and a well invited challenge and next step in my path to developing as a model ship builder. View attachment 303692
This one is as big as my back seat which is crazy. I have been looking at logs and diagrams for weeks and once I got the ship home i did the normal check over the whole kit and found that unlike most of models where it's a set of plywood for the skeleton this kit comes with particle board. It's lighter but it doesn't feel as strong which leads me to believe that is why most modelers use balsa blocks in the slots in-between the bulk heads. View attachment 303693View attachment 303694View attachment 303695
Nice aligned and doing an overnight dry so I can start in morning on the deck. And start getting some next steps done.
Yep it's all one piece so the box is 36" long and I would need to see how your instructions were to see if there was a difference but they are quite understandable and seperated out quite nicely too. I feel the rigging will not be as bad to figure out as my last shipAt first I thought your car to be very small! Then it occurred to me that OcCre have revised the kit, as mine came in a box 24" long x 16" wide. I guess the false keel is now one-piece, not two. I hope the rigging instructions have also been updated, as these have been known to cause much head scratching. Mine took me 15 months to build.
Stuart
And sorry for the stupid question but waterway is the side panels that have the gun ports in them? But I will check all this for sure.Check how the waterway will fit all that goes on the outer edges. That’s where you can make it up but check whatever goes inboard too because those holes all take something. There’s always a fudge factor but 1mm off times a large span equals quite a bit of a mistake.
I wish I was lying but I just did another check over all the plans that are online and the paper ones and there is no mention of water ways or planking on the edge before the top timber or an iron hanging knee or hold beam shelf or any of that.....so looks like I need to do some mods or be ok with it....(which I don't think I can be ok with that)If you have plans there you should be working off them 100% if possible. There has to be waterways in the kit,
this is my first attempt of putting some realistic wear on the walk paths of the deck. I feel like I did a decent job at this and will be making the top deck lighter because it's where the sun will be hitting the deck the most. I am going to put a matte layer on this to try and protect it once I figure out where the ladders will go and make sure all the patching is aligned.
