Workshops My shipyard/your shipyard
My basement workshop/shipyard in all it's cluttered glory. I thought about tidying it up before posting but I was too lazy to do so. I also do model railroading so you will see parts related to that hanging around the laptop.View attachment 434476
Great to see your workshop - a "busy" wokshop
and most important to see, that you have ShipofScale opened on your laptop - good tools and a friendly forum - what else do you need to be happy
Thanks guys the table sure is made of 100% faux-cherry-compressed wood :D. @Uwek I do have some particle board to cut & splice and my self healing mat is in some boxes not sure which one though need to look for it, I do cover my work area with the instruction sheet, probably not a good practice but it is what I do. Thanks @Jack Sparrow it is neat its what I'm leaning to do next due to me being a bit wary of me doing the rigging on the Torborg and would like to get my feet wet with planking a bit more . I also got some Cottage industries Subs too but they are resin (Hunley, C.S.S. David, Alligator, and the 1800 Nautilus) thinking of doing the Nautilus after the wooden sub since it has a sail with simple rigging.
And definitely you need a cutting mat - green coloured -> your table will be happy, that the surface will be protected
...then, you become a proud member of the GCMO (Green Cutting Mat Owners) group, and they (the group), will be happier than your table. ROTF ROTF ROTF ROTF ROTF ROTF
Hi Everyone
Wow A lot of these shipyards are brilliant only wish I had that kind of space to get properly organised with Tooling etc..
Well here's my Humble Shipyard not much I know but adequate to get the job done, maybe some day I will be able to fully open up the folding table.
All the best
Rob :)
Hi Everyone
All the best
Rob :)
beautiful ships there. Just shows that it is the skill of the builder and not the size of the shop that makes the difference. :)
Hello folks
It's been long time since I posted about my ship modeling of the Saint Phillipe 1693 POF journey. All this time I has been snowed with lots of work and also waiting to move in another location and start building my first proper shipyard.
Here are some pictures of my small shipyard which is still not a permanent solution as I will be relocating soon, hopefully to something permanent this time.
As you can see my work is done on two work benches made from a solid 4cm thick birch worktop. The one workbench I use for the ship construction and the other one is for general modeling work. On the workbench I have the machines I use most often; the Proxxon/Emco Unimat milling machine (this is an upgraded small milling machine I have modified), the Byrnes table saw, the Proxxon TBH bench drill and the Proxxon PD 250/E metal lathe.
For keeping my shipyard clean from dust (and my partner happy:D) I have made an acrylic foldable protector which is designed to help reducing the transmission of dust to the surrounding areas of the machine which i use each time.
In the corner of the room I also have a storage shelf unit where i keep the rest of my electric Proxxon tools (Proxxon DH 40 thicknesser, Proxxon AH 80 surface planer, Proxxon GS 80 mitre saw and the Proxxon MF 70 milling machine. I have also a wooden tool chest for the small engineering tools.
Also, I have a dedicated wooden shelf for storing my timber for the ship modeling; it includes mostly pear wood species as well as other exotic hardwood and boxwood for carving. On the top of the shelf I have a small wooden organizer for my collection of the mini hand planes (this is something for a future dedicated post!).
Hello everyone,
I built my new workshop in January 2022, I think some of you can still remember it. Since then, one or two machines have been added (lathe, 2nd milling machine, etc.), also more wood and so a lot had to be changed. It all started with me rebuilding the construction table to have more space for my wood. One thing led to another and so I decided to organize everything a little better and make it more friendly. See for yourself.
Before
After
I can see the cyclone dust collector, how it works, and the vacuum cleaner itself, is it placed in the same room, I'm thinking about less noise from the vacuum cleaner, Knut-
Hello Knut,
I decided on the Festool vacuum cleaner because it only has 67dB. According to measurements under load it is 73dB, suction power is sensational even with 10m of pipework and cyclone separator.
Hello everyone,
Before
After
You know.....it's not NEARLY messy enough! You need to get busy!
Witaj
Tobiaszu taki warsztat to marzenie każdego modelarza super . Pozdrawiam Mirek
Hello
Tobias, such a workshop is every modeler's dream. Best regards, Mirek
Hello everyone,
Before
After
Hi Tobias,
You have a beautifully organized workshop and all that strip wood in stock, wow.
The large blue box hanging off the ceiling, is that an Air purifier?
Cheers,
Stephen.
Hello everyone,
Before
After
Wow that looks brilliant!
All you need in there now is a Bed, a mini Bar and a TV ;) :)
