Is there a reason you can't just shorten (pare down) the inner wall?
I think that could be done, but there are two more pieces that fit on top of that plank.Is there a reason you can't just shorten (pare down) the inner wall?
Good afternoon Jan. ….and I thought I alone made those kind of blunders…I agree must be the heat stroke. Why don’t you just shape down the inner planks to fit, unless I’m missing something? Cheers GrantOh boy, the "Bumbler" has created a problem.
The plan.
The how to do it video
What the "Bumbler" did.
The inside planking juts just a "WEE" bit above the hull planks. Both the SB side and Port side have the same problem. I'm blaming the build error on "Heat Stroke". It's been over 90F/32C most of the week. That temperature when corrected for high Humidity places the temperature well over 100F. (Can't cool off in the pool, the water temperature is over 85F)
I think I'm going to take a break and try figure out what went wrong. It's going to take some careful ungluing to do a "Do-Over"
Jan
WhewI think that could be done, but there are two more pieces that fit on top of that plank.
I sort of leaning to eliminating or parring down plank #6. But first I need to work on the cap rails that cover that area. I want to assure myself that I'll have good fit before I make any "adjustments"
Jan
Yup, little bit of a puzzle. I can see doing it wrong on one side.Whew.
Good morning Jan…these are the best! Let the sanding dust flyA very productive day.
Good jobIt’s the simple “I should have done” things that complicate things later on.
The build plans. Add these pieces to the frames.
Add these pieces to the SB and Port sides.
It never occurred to me to test fit the beams to make sure all the openings lined up properly.
I used some 1/4 X 1/4 inch dowels to test fit the openings this morning and had a 60% success rate. Ha “3 out of 5 “ ain’t bad. The remaining two required creative filing and sanding to get a good fit. Plank #38 needs to be marked to reflect the location of the openings and then be glued into position. That completes the hull planking.
Yup, just a little omission on my part few weeks ago caused a minor “oh rats” and a $1 bill added to the jar.
Jan
@Freddie.Well I guess I'll have to move on to something else for a while. That's a lot of parts missing on 4 plates. Who knows how long that will take to get. I hope they can send them to me or else this will be expensive kindling!
Hello, interesting, what is this tool for? Where do you sell?Another off topic item. My Sister in Law picked up this little gadget at a yard sale yesterday. It will go on the assembly list for later.
Chamfering tool in original packaging. I don't know who makes it.
Instructions that I found on line.
Looks like a neat gadget, anyone use one of these???
Jan
