Thanks for sharing your jig. How did you cut the brass into strips?
Think brass strips are harder to find because they are usually sold out. but here are some, Paul: LINKThanks for sharing your jig. How did you cut the brass into strips?
just bought 2 bags! GrazzzieHaving bought two sets of them before, I can tell you they are 12" long.
Hallo @tfcobraThank you gentlemen for your input. Phil, I will continue to watch your excellent build as I order my kit.
No need to improve something that has proven to work wellGo right ahead...maybe even improve it?
I like your choice of colors. They go great together.Build Log: Nuestra Senora del Pilar (OcCre, 1:46)
Continuing on with getting armament built and installed. This log portion shows the cannons being placed on the decks. It only includes the first 16 cannons. More to follow. I need to blacken the barrels of the next groups before I install them.
I found that I pre-drilled holes in the bulwarks a little too small so I had to chase the holes with a larger drill bit. Since the cannons needing attention were below deck, I had to contrive a way to allow the drill bit to reach. What I found was the handle of one of my micro saws worked nicely to hold the drill bit tightly and allow me the reach (distance) from one side of the ship to the other. I installed the eyelets in place with a tiny drop of CA.
Next up - the addition of channels and deadeyes and all their associated hardware. I have a lot of brass rod to bend and solder to make it all come together.
Please let me know if you have any suggestions or comments.
View attachment 345979View attachment 345980View attachment 345981View attachment 345982View attachment 345983View attachment 345984View attachment 345985View attachment 345986View attachment 345987View attachment 345988View attachment 345989
