- Aug 30, 2020
Thanks Jimsky, I sort of tried something similar but just shaking a sandpaper lined container without a drill, it didn't really do much.Hi Richie, I think, Francesco talking about this or a similar tool.
Model Shapeways BLOCK BUSTER - HIGH-SPEED BLOCK SHAPER
Want more realistic and better-looking blocks for your ship model? Then, you need our Blockbuster! The secret is in the sandpaper lining of the cylinder. As you spin the cylinder, the blocks tumble around and rub against the sandpaper, taking on the smooth, rounded shape of real blocks. You can process dozens of blocks at a time. Blockbuster is easy to assemble and operate. Electric drill required for operation.
Is that a centre spindle that has sandpaper attached that spins from the drill rubbing he blocks against the sandpaper lined container, looking a bit like the image.
