- Sep 28, 2020
Great work Matt!
Beyond words! How did you make that gorgeous block strop with hook?Hi All,
Another episode of ropes and accessories
So currently I'm working on "upper level" of standing rigging like top shrouds and stays.
However, it's a good time to consider some other parts to install at that stage, so meanwhile I'm adding stuff like topmast rope and block or leechline and buntline blocks attached to the sides of main shroud eye.
It will be easier now and this way when there is some more space for fingers and not many ropes around.... later it might be
You can see also, that I've manage to do main yard halyard with one of the biggest block (ramshead) on this ship, hanging quite high above the deck
Main yard is just test fitted and it will be removed.
Now it's time to jump to foremast top as it has similar "setup", but with just a little bit smaller rope diameter and blocks sizes.
Then last stay, which is fore topmast stay and somewhere in between futtock shrouds... and I will be ready to start with standing rigging tension adjustments and most likely fixing it in permanent position (hopefully )
Cheers,
Matt
every day something to learn - many thanks for the detailed information - hope, that here Mondfeld was correct, but I guess yes@Steef66 thank you for your comment. Good luck with your rigging PW has more complex rigging... so it's a challenge to do it right
@Uwek thank you also for your nice comment.
Regarding your doubt:
This is actually quite interesting thing.
Ships were rigged with shrouds either left or right-handed on both sides, but also right-handed on port (larboard) side and left-handed on starboard side (this was not commonly in use)
For right-handed ropes short ends of the shrouds seized around the deadeye should be to the right to standing part (looking from inboard).
So... for all right-handed shrouds... looking at them from outboard... port (larboard) side, short ends should face forward of the ship... and for the starboard side short ends should face aft of the ship.
if... all shrouds are left-handed... then short ends should face: on port side - aft and starboard side - forward
if... port side has right-handed and starboard side has left-handed shrouds then all short ends should face forward.
Nicely confusing... but really interesting
Obviously... I'm too dumb to have this knowledge from myself
I'm freely quoting Mondfeld
Cheers,
Matt
