Pocher 1:8 scale Porsche 917K
As a detail lover: The straps for that spare tyre looks very good, Dean. :)
Please, not too many details at once in a evening ………. It will make you drunk ……...ROTF
Thank you Peter, I’m not 100% happy with them. And when people compliment it, I will say there are things I wish I would have done better (that being one of them). And that’s my normal response because I can’t achieve perfection! ROTF But I can strive for it and settle for my best effort. ;)
Step 27…
A lot going on here… building the headlight assemblies, the rear view mirror, the top of the firewall with window, the rear ducts for the transmission cooling, joining the tail of the body, adding the headlight assemblies, and adding the strut for the rear to open.
The headlight assembly parts as provided…
The chrome plated part below the headlight buckets shows…sigh…
So I will have to paint those black first…then assemble the headlights.
The scary part as always with glass, is gluing them without squeeze out that fogs the glass or leaves an ugly blemish. Never use CA glue! I have learned to be very careful and apply the glue to the piece the glass will go on, never the glass itself! Second, use as little glue as possible, better to have to glue the part again than get excessive squeeze out and ruin the glass (which is plastic).
My complaint with these, is the clear headlight lens were actually a little too big to sit in the bucket and seat all the way…sigh! So I had to put glue on the face of the bezel and sit the lens on top carefully.
Anyway, here they are…
And on the body…
The mirror and upper wall with glass…
And finally the rear with cooling ducts that line up with the pieces on the transmission when it is closed.
As you can see they actually sit inside the vertical riser on the chassis for the cooling ducts when closed …cool design! And of course the strut is attached.
So I survived this step. Next will be more glass for the windshield, doors and to cover the headlights. They should really consider designing the kit to have the glass snap in place verses gluing. But hey, who is afraid of another challenge? ROTF
In addition, when the body is joined to the chassis, I then have to reach inside the front hood area and connect the cooling hoses for the front brakes and cabin. ;)
Step 28…
A lot of glass…
Attaching the brake cooling hose to the front vents was an experience of pure frustration. I had to look through the wheel well with a flashlight while I tried to attach the hose with tweezers from the hood opening!
The windows needed the screws or rivets painted silver…
Then I painted the Bolts and wiper blades on the wiper assembly…
Then the front grill needed painting, was black plastic…
After dry brushing silver…
A peak under the hood…
Then I finished Installing all the glass…and went to step 29…
The body is finally attached to the chassis!
And why not do the next step…
Adding the lower body panels.
Some pics of current progress…
Now to start making wheels… time to get her on her feet! ;)
Steps 30,31 and 32…
This was a little more work than appears.
First was cutting rims off the sprue and sanding the tabs from injection. Then I soaked the tires in hot water for 10 minutes. Then I added some liquid soap to the front edge and around the outside of the rim and put the tire on right after removing from the hot water. This still took some effort to push them on using the palms of both my hands 180 degrees apart on the tire while the rim was on a hard surface.
Once the tire was on properly, I dried the water off both the tire and rim with a hair dryer. Then I sanded the tire treads to look driven on, and then I added the decals to each spoke. And then I added the valve stem after painting the cap black and doing a wash. The tire assembly was then screwed onto the car and the center hub was glued on the rim after adding a wash.
The rear rims had one extra step of gluing the two rim halves together.
You can see the brake rotors and calipers, but they don’t show up real well on the camera. I will get some better pics when I take the finals.
Then was step 33…
I have added the pieces for the flaps and rear latches. I have decided I do not want to display the velocity stack covers that were not used when the motor was running. I also don’t want to add the top filter cover as it hides the injectors, tubing and other details. That was not always used anyway. I also removed the spare tire because it blocked the view of too many details. ;)
The rear prior to adding the parts…
The parts as provided…
Looking at this reference photo of a real car…
I then painted the bolts appropriately and added a wash to all parts.
On the car…
A few extra pics…
Now to add the final decals and take final pics of the car to wrap up this build. Looks like I need to start thinking about a case for it! ;)
Continuation…
A few on my workbench…
And the weight! 13.4 lbs!
And finally next to my Lotus 72…
Conclusion,
I hope my build has enlightened anyone looking to purchase or build this kit. I tried to show all of the parts as provided and how I modified them to make a better model. It certainly had a few challenges along the way and some assembly steps were plain frustrating! But it is a nice kit and can be built into something worth displaying.
So that’s it, happy modeling.
Continuation…
View attachment 510385View attachment 510386View attachment 510387View attachment 510388
View attachment 510390View attachment 510389View attachment 510391View attachment 510392
Conclusion,
A very nice build of this Pocher Porsche, Dean. And it is unique with all your added details!
