POF Hayling 1760
Good evening.I started installing the outer skin and immediately ambushed.if the rail is exposed along the tops of the ribs, then a gap of 2 millimeters appears.after viewing the photos of the test build, I realized why the gap appeared.the guys from the company had a black rail on board there.then they removed it, but they forgot to recompile the skin.I inserted my rail.it's a little wider but quite a bit.I hope this will end the problems with the cladding.
Hi. Tell me, did you put a 2mm or 3mm wide strip there? That's a significant design flaw...
