POF Hayling 1760
Your hull is coming out nicely after sanding - so good work in the preparation of the frames Thumbsup
Good evening.I started installing the outer skin and immediately ambushed.if the rail is exposed along the tops of the ribs, then a gap of 2 millimeters appears.after viewing the photos of the test build, I realized why the gap appeared.the guys from the company had a black rail on board there.then they removed it, but they forgot to recompile the skin.I inserted my rail.it's a little wider but quite a bit.I hope this will end the problems with the cladding.
Hi.I continue my story.installed a barkhout.these strips were difficult for me.I painted them before installing.but since it stuck badly, I had to polish them.I'll have to paint it one more time.and I chewed off all the protrusions of the ribs except the front ones.That's it for now.
Good night.something I can't sleep and I decided to work out with the boat.installed the handrails of the hull.in the stern, I decided to cut them into the aft part.I don't know what it's called.so that he would go to the very end.
Good evening.there was such a question.the case is moving to the mast and rigging.there is a desire to order ropes.but I do not know what size to order.does anyone know what ropes I'll need?
Hi.sad news.there is no friendship with steering wheel loops.they break down and fall apart.apparently I'm stupid and ru and I have curves for such a small job.I will think something , sculpt my own from the wreckage (((
Hi.a new question.on the assembly plan, the threads are indicated by numbers and letters B0,4.0,6.0,8.10.could it be the thickness in millimeters? For example 0,4mm0,6mm or 1mm
