POF Hayling 1760
Good night, dear forum members.I decided to show how I assembled the floor base of the aft cabin.after considering my steps, I decided to reverse the order of assembly.first, I installed the base of the spire.then I laid the extreme beams.I glued the props under them.in the end, I installed the middle beams.
Houston, we have a problem.I disassembled the knot and moved the stern.but then she gets up crookedly.do you have any close-up photos of this node?
Good evening.a new question.I assembled the racks for the windlass.but the design turns out to be higher by 5 mm.what should I do? Saw off the legs at the rack or lift the props?
Thank you very much.this is not in my instructions.there is an opinion that she, the instruction, is cropped.
Good evening comrades.I have a new question.where are the details of the lining of the inner side ?
Good evening.thanks for the reply.there are no separate strips of wood in my set for the settlement.I will put my own.I have it, I bought it for the keel, there are extra ones left.I liked using a compass as a clamp.I bought it on AliExpress.I ordered a few more .they fit very well.they are cheap.
I was wondering how this kit could be so affordable, but with as many problems I see you are having I guess the old saying is true…. You get what you pay for….but it is still looking great- you have great talent and skill Novichok!
Good night.thank you for your kind words.the set is good.a bad instruction spoils it.she's very weak.shows only the general direction.but it's only more interesting.the grinding of the case is coming to an end.I'll start doing the sheathing soon.
