Ragusian Galley by Don Robinson - MarisStella
Hello all and a Happy June 1st. Thanks to you all for your likes comments and for just stopping in, it is all much appreciated.
A short but sweet little update. I took the Galley for her first visit outside for some pictures, it's a beautiful day here.
The stern railing is now completed
And the stern decorations
I just thought this was kind of a cool picture
One final picture.
Next up is the cannons for the bow. Hopefully this won't take very long and maybe the grass will be a little greener!!
Have a great weekend!!
Hello all, thanks for all your visits, likes and comments.
Since last we met I have completed the stern windows and installed the cannons c/w carriages. Not really that much shipyard work but yard work and various other tasks have been keeping me busy.
Cutting out the spots for the windows
The carriages are laser cut cap squares(trunnion straps) are photo etched along with the insignia which are glued on to the barrels
The window frames are laser cut and the window gratings are photo etched
That's it for now. Next up is doing a few touch ups then the rudder and tiller
Later
Hey all you modellers, how is your day going? Thanks to you all for visiting, liking and commenting it is great!
Some more work has been done on the galley and I thought you may like to see:
The rudder is 3 pieces of laser cut walnut, the top part that goes through the hull requires a little shaping. The tiller is also laser cut but in my case I needed to make one from scratch as the supplied one was ruined by the modeller!o_O Pins were soldered to the photo etched straps then bent to shape. These were later cleaned up and painted
Here is the tiller attached to rudder. I was worried about the roped part being out of scale but it works out to around 14 cm so that should be ok, as long as Shrek is the helmsman
The flagstaff is made from walnut dowel the top is made from a larger dowel that was drilled out, glued in place then followed by some shaping. The straps were also photo etched that were shaped and painted.
At the bow the spur was installed along with the holder thingy(don't know proper name for this piece).
Another angle of the tiller and flagstaff
Stairs were also completed and installed. The sides were laser cut and showed where to cut the rabbets for the steps
And a full shot showing the completed rudder installed. I just noticed the bottom strap on the rudder probably should be black or the part on the hull changed. I will give this some thought.
Thanks everyone for stopping by, hope you enjoyed the update. Next up is the 30 oars needed and another sail to make. Rigging is soon to come!!!!! Should be exciting. Haha
Have a Good One
