Rainbow J Class 1934 America’s Cup Defender - Amati - 1:80 Scale by Barry1
A beautiful classic yacht - she is looking great Thumbsup
Congratulations for this built
Also building the Rainbow - Have gotten to the decking and was going to go with straight planks parallel to the centerline and a very outer plank curved to give a clean edge - do you think this would work? - Any reason you went with the curved decking? My 1st model and trying to minimize the complexity
THanks
THanks
I tried to follow the instructions which indicated a tapered look. While this may be more historically accurate if I had it to do again I would have done what you are planning as well. Hope this helps.
This way of planking is seen in a lot of classic yachts. The planks meet in the middle in the King Plank, see sketch below. It gives your model a fantastic look to do it that way as it emphasizes the shape of the hull.6a010536216f64970b01b7c8879dcf970b-800wi.jpg
The instructions indicate using a clear wood filler before finishing the deck - Any recommendations?
Barry 1 - I am putting on the railing and finding the copper colored tube to be too large to fit in the eyelets of the eyebolts - did you have a similar issue?
I did not have this problem. I did test fit the tubing prior to installing the eyelets. The eyelets worked for me. If they are close perhaps a little lubricant such as WD40 might help. The other the idea would be to go to a hobby store like Hobby Lobby and get a smaller tube size that will work with your eyelets. Your ship is looking good!!
Barry 1 - Do I read this correctly that the 2mm blocks get tied with string to the hooks? Any recommendations?
Thanks for your help
Sal
