clever idea ....
Dear AlexanderOn the poop deck I revised and attached the deck pieces again. I carved the interior carvings on the hackbord. These don't really correspond to the carvings on the original model. I'm considering changing something there. In order to achieve an optimal fit, I would have to remove parts of the rear figures. Maybe, I will redo it.
After that, I continued with the rudder. I prepared the rudder three years ago. Here is the rudder with the brass connection for the whipstaff:
The pintles of the rudder on the original model are missing. It is no longer possible to determine whether these have been lost or whether they were dispensed with from the outset.
So I thought about how to make this connection. I prepared the pintles in the form of four 1mm thick pins. To get them in the right place, I drilled slanted holes in the rudder blade above the cutouts (see the blue lines in the photo).
There the pins were inserted and the rudder blade pressed against the upside down model. Then the model was rotated. The pins slipped out of the holes in the eyelets of the gudgeons. It had to be helped with tweezers until they were properly seated in the eyelets
The result fits and I felt a load lifted from my heart that the uncertain plan I had made 3 years ago has now worked out.
Still the obligatory proof photo that shows, that the connection between tiller and whipstaff is there. It won't be visible later because I will show the gunports closed.
Cheers, Alexander
But we know it - Very good work my friendIt won't be visible later because I will show the gunports closed.
Yes, we almost had that with up to cu 19 degrees but from tomorrow the snow is supposed to come back.It seems, that you have summer in Munich !?!?
Very good work my friend - and a Happy new year
Also to Karl Ingwer - all the Best
